I'm looking at Build issue 165 raised by @LN trying to figure out precedence of the auto-send and auto-delete submission attributes of an Xform in ODK Collect (which has its own project-wide submission send/delete settings).
EDIT Found the correct format, Collect uses form settings over project settings.
Ref:
- XForms spec on submission attributes
- XLSForm spec doesn't mention auto-send/delete, but
- pyxform seems to support it
- Collect docs on auto-send and auto-delete mentions Collect form management settings, but no XForm submission attributes.
- ODK docs for "submission attribute" don't mention auto-send/auto-delete.
- Haven't yet read Collect source code to determine its intended behaviour.
Versions
- Xform built by Build 0.4.1, hand-edited to include submission attributes
- ODK Collect v2021.3.4
- ODK Central 1.3.0
Experiment 1: Form says auto-send/delete, Collect says no
Add <submission orx:auto-send="true" orx:auto-delete="true"/> as child of the <model> node (EDIT: not sibling of model).
<h:html xmlns="http://www.w3.org/2002/xforms" xmlns:h="http://www.w3.org/1999/xhtml" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:jr="http://openrosa.org/javarosa" xmlns:ev="http://www.w3.org/2001/xml-events" xmlns:orx="http://openrosa.org/xforms" xmlns:odk="http://www.opendatakit.org/xforms">
<h:head>
<h:title>Translation268</h:title>
<model>
<instance>
<data id="Translation268" orx:version="1641370518">
<orx:meta>
<orx:instanceID/>
</orx:meta>
<text_1>
Text 1 default
</text_1>
<untitled1/>
</data>
</instance>
<itext>
<translation lang="English (en)">
<text id="/data/text_1:label">
<value>Text 1 label en</value>
<value form="short">Text 1 short en</value>
<value form="image">jr://images/text1.jpg</value>
</text>
<text id="/data/text_1:hint">
<value>Text 1 hint</value>
<value form="guidance">Text 1 guidance</value>
</text>
<text id="/data/text_1:constraintMsg">
<value>Text 1 invalid</value>
</text>
<text id="/data/untitled1:label">
<value>label 2 en</value>
<value form="short">short 2 en</value>
</text>
</translation>
<translation lang="Bavarian (bar)">
<value></value>
<value form="short"></value>
<value form="image"></value>
</text>
<value></value>
<value form="guidance"></value>
</text>
<value></value>
</text>
<value>label 2 bar</value>
</text>
</translation>
</itext>
<bind nodeset="/data/meta/instanceID" type="string" readonly="true()" jr:preload="uid"/>
<bind nodeset="/data/text_1" type="string" jr:constraintMsg="jr:itext('/data/text_1:constraintMsg')"/>
<bind nodeset="/data/untitled1" type="string"/>
<!-- EDIT: submission must go here -->
</model>
<!-- EDIT: submission does not go outside model but inside -->
</h:head>
<h:body>
<input ref="/data/text_1">
<label ref="jr:itext('/data/text_1:label')"/>
<hint ref="jr:itext('/data/text_1:hint')"/>
</input>
<input ref="/data/untitled1">
<label ref="jr:itext('/data/untitled1:label')"/>
</input>
</h:body>
</h:html>
- Set Collect to not auto-send and not auto-delete.
- Fill and finalise the form.
- Collect follows
<submission orx:auto-send="true" orx:auto-delete="true"/>from the form overriding its own "do not send/delete" settings.
Experiment 2: Form says DO NOT auto-send/delete, Collect says yes
- Same form, but with
<submission orx:auto-send="false" orx:auto-delete="false"/>. - Collect set to "send on WiFi", delete sent.
- Collect follows the form's
<submission orx:auto-send="false" orx:auto-delete="false"/>settings.
EDIT: found correct format, XForms auto-send/delete overrides Collect's form management settings. This behaviour seems logical.
