Something broke the parser. See above for a hint.
Error evaluating field 'Building_alliances_Calcualtion' (${test}[1]/Building_alliances_Calcualtion[1]): The problem was located in Calculate expression for ${Building_alliances_Calcualtion}
XPath evaluation: cannot handle function 'IF'
Caused by: org.javarosa.xpath.XPathUnhandledException: The problem was located in Calculate expression for ${Building_alliances_Calcualtion}
... 10 more
The following files failed validation:
${test}.xml
Result: Invalid
What is that mean, when telling {XPath evaluation: cannot handle function 'IF'}, and how to solve this problem.
I got almost the same feedback and i am stock
Can someone please help me.
I am new:
ODK Validate Errors: >> Something broke the parser. See above for a hint. org.javarosa.xpath.XPathException: XPath evaluation: Parse error in XPath path: [instance('countries')/root/item[Lao PDR]]. Couldn't understand the expression starting at this point: .../root/item[Lao͎PDR] The following files failed validation: ${tmp_qdurmxg} Result: Invalid
Your file should have the .xlsx, .xml file extension because Ona uses XLS Forms to create forms.
Not sure what to do? Read more aboutUsing XLSForms
Lao PDR_eSurv.xlsx (163.9 KB)
HI
Thank you for your response.
Please see the attached file of the project i was trying to create and help me to identify my errors.
The first mistake is in row 11 in choice_filter column. You have there Lao PDR. I think what you wanted to add is countries=’Lao PDR’?
Then there is another bug in row 58. The question name is list_of_community_informants and the logic you have in relevant column is ${list_of_community_informants}='Y' or ${list_of_community_informants}='N'. You can't hide/display a question based on its own answer.
