Hi there,
I've got a repeat group in my form and I would like to ensure that one of
the questions inside will not accept the same value again when repeated.
Ideally I would like to use the current repeat count to populate the field.
Is there a way of counting which repeat I'm currently on and using that
number as part of an ID for a field inside the repeat group?
Any suggestions/useful links on this are much appreciated!
Hi Korinna,
You can count the number of repeat you are on with position(..), but I
can't think of an easy way of using that count as part of the ID. Once
you are outside the repeat, you could probably use indexed-repeat
(https://opendatakit.org/help/form-design/binding/) to check for
duplicates and then warn the user then.
If I had this problem, I'd use a fixed number of questions instead of
repeats because it's so much easier to reason about.
On Wed, Apr 20, 2016 at 1:12 AM, Korinna Pinakoulaki korinnapinakoulaki@universaldoctor.com wrote:
Hi there,
See this: https://opendatakit.org/help/form-design/#xpath_expressions
Doing this is generally tricky.
If your data-entry values are constrained so they do not contain embedded
spaces, you could use join(" ", ${repeatedfield}) to construct a
space-separated list of values.
The following should then work assuming the repeatgroup is immediately
enclosing repeatfield:
selected(join(" ", /path/to/repeatgroup[position(current()/..) !=
position(.)]/repeatedfield), .)
Where:
/path/to/repeatgroup[position(current()/..) != position(.)]/repeatedfield
takes all repeatfield values that are not from the current repeat of
the repeatgroup.
If you do allow spaces, I don't have a solution.
On Tue, May 3, 2016 at 11:32 PM, Yaw Anokwa wrote:
Hi Korinna,
Hi there,
field.
Hello Mitch
Can you please send an example in xlsform of what you explained please?
> If your data-entry values are constrained so they do not contain embedded spaces, you could use join(" ", ${repeatedfield}) to construct a space-separated list of values.
> The following should then work assuming the repeatgroup is immediately enclosing repeatfield:
> selected(join(" ", /path/to/repeatgroup[position(current()/..) != position(.)]/repeatedfield), .)
> Where:
> takes all repeatfield values that are not from the current repeat of the repeatgroup.
> Hi Korinna,
> Yaw
> On Wed, Apr 20, 2016 at 1:12 AM, Korinna Pinakoulaki wrote:
> > Hi there,
> > Thanks
> > You received this message because you are subscribed to the Google Groups
> > "ODK Community" group.
> > To unsubscribe from this group and stop receiving emails from it, send an
> > email to opendatakit...@googlegroups.com.
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
