I'd like to know if there is an xls syntax for piping the respondent's Name
(ex. Matt), such that when the next question comes up (ex. What is [NAME's]
gender?), the [NAME's] automatically changes to the respondent's actual
Name (ex. What is Matt's gender?).
Secondly, I need some help with constraining the phone number such that the
enumerator is required to entering a phone number that is between 7-10
characters (integers) long, with the country code as the required integers
for the first three characters. Is there a way to accomplish that in xls?
For the first, you need to add something like this for the prompt
label. So if you wanted to ask someone their age, you'd put this:
"Hello, . What is your age?"
For the second, you need a regular expression constraint (read http://www.regular-expressions.info/ for more). For example, this
constraint will allow only alphanumeric input that is 4 characters
long.
regex(.,'[A-Z0-9]{4}')
Hope this helps,
On Fri, Sep 14, 2012 at 10:21 AM, m_optimal wrote:
> Hi ODK Community,
> gender?), the [NAME's] automatically changes to the respondent's actual Name
> Thank you for the help!
> Michael
Hi Yaw, i'm trying to specify the format of the phone number where i can insert characters such as: 11-111111
Is there a sintax in odk/xls to specify this kind of format that would characters and not only numbers?
P.S: i dnt want the question type to be a 'text'.
Greetings!
I'm trying to use regex, but, appearance is not showing as numbers only,
could anyone provide further assistance -seems this is a very old thread-?
I want a mobile number only as answer
type= text name= mobile number label=Mobile Number required=yes
constraint_message=10 digit number! appearance=numbers
Also, remember that integers are limited by binary representation to 9
decimal digits. If you want something longer (e.g., 10 numbers) then make
sure to use a string data type and not integer.
Gaetano
On Fri, Sep 14, 2012 at 7:30 AM, Yaw Anokwa wrote:
Michael
Both of these are somewhat advanced operations.
long.
Name
[NAME's]
Name
the
integers
Thank you very much Yaw and Gaetano. Just to be clear, when you mention
"prompt label" you mean the column named "label", yes?
Michael
On Friday, September 14, 2012 10:31:21 AM UTC-4, Yaw Anokwa wrote:
> Michael
> long.
> Hope this helps,
> Yaw
> On Fri, Sep 14, 2012 at 10:21 AM, m_optimal <mmana...@optimalsolutionsgroup.com > wrote:
> > Hi ODK Community,
> Name
> [NAME's]
> Name
> the
> integers
> xls?
> > Michael
I have a question about the regex constraint you mention below. I tested
this out (as a constraint in xls forms) and found that it restricts the
number of digits correctly but only allows input that begins with letters.
I'd like to be able to restrict to alphanumeric input, regardless of
whether it begins with numbers or letters. Is this possible? Can you please
advise as to the constraint that would accomplish that.
Thanks so much for your help.
Audrey
On Friday, September 14, 2012 5:31:21 PM UTC+3, Yaw Anokwa wrote:
> Michael
> long.
> Hope this helps,
> Yaw
> > Hi ODK Community,
> Name
> [NAME's]
> Name
> the
> integers
> xls?
> > Michael
Use regular expressions (regex). Something like
regex(.,'[0-9]{2}-[0-9]{6}') would be what you'd use as the constraint
for your example. For the regex to work, you should use a text prompt,
but with appearance=numbers.
Need ODK consultants? https://nafundi.com provides form design, server
setup, in-field training, and software development for ODK.
Note: this appearance setting changes the Keyboard style of the pop-up
keyboard to the calculator / number keyboard when you attempt to enter data
into the field. It does not prevent non-numbers from being entered. This
relies upon the device's keyboard supporting and reacting to this setting ( http://developer.android.com/reference/android/text/InputType.html#TYPE_NUMBER_FLAG_SIGNED
You need to add a constraint restricting the input string to something that
looks like a phone number.
e.g.,
for a ten-digit number:
regex(${mobile},'^[0-9]{10}$')
On Tue, May 10, 2016 at 10:17 PM, Sergio Del Villar wrote:
Greetings!
In XLSForm, the syntax is slightly different -- you would enter "Hello,
${firstName}. What is your age?" in the 'label' column.
This substitutes the value from the question who's 'name' column is
'firstName' into the question text.
On Fri, Sep 14, 2012 at 11:19 AM, m_optimal < mmanansala@optimalsolutionsgroup.com> wrote:
Michael
Michael
http://www.regular-**expressions.info/http://www.regular-expressions.info/for more). For example, this
long.
Name
[NAME's]
Name
the
integers
xls?
The example I used was just uppercase. Try [A-Za-z0-9]{4} if you want
to include lower case.
On Wed, Jan 30, 2013 at 10:28 AM, wrote:
> Hi Yaw,
> I'd like to be able to restrict to alphanumeric input, regardless of whether
> it begins with numbers or letters. Is this possible? Can you please advise
> Best,
> Audrey
>> Michael
>> long.
>> Hope this helps,
>> Yaw
>> > Hi ODK Community,
>> > Name
>> > [NAME's]
>> > Name
>> > the
>> > integers
>> > xls?
>> > Michael
> "ODK Community" group.
> For more options, visit https://groups.google.com/groups/opt_out.
There is no template feature for numeric input. If you want to enter/have
non-numeric characters, you must use a text field.
And note that regex() only works on string values. If your field stores an
integer data type, you must convert the value to a string before using
regex.
I.e., for integer input, you could use:
regex(string(.),'...')
BUT, the value of string(.) would be after whatever you entered was
converted to an integer, then printed back out. So if you entered 0004,
string(.) would be just 4.
On Wednesday, May 11, 2016 at 12:01:49 PM UTC-5, Mitch Sundt wrote:
> appearance=numbers
> that looks like a phone number.
> e.g.,
> On Tue, May 10, 2016 at 10:17 PM, Sergio Del Villar <sgd...@gmail.com > wrote:
>> Greetings!
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
letters.
whether
advise
Audrey
Michael
long.
Name
[NAME's]
actual
Name
that
the
integers
xls?
similar with the previous questions about inputting number, is there any
way to have number field automatically separated by comma or dot (like in
MS Excel)?
With the default, there are many errors in typing number, especially the
long one. For example, to input 100 million then we have this format by
default: 100000000.
It is easy if the field automatically converts the input into 100,000,000.
First, make the question required. Second, add the start/end
characters (^ and $)
Final XML should look like...
On Wed, Jan 30, 2013 at 11:09 AM, Audrey Henkels wrote:
> Hi Yaw,
> Thanks for the speedy response. I made the change, and unfortunately, now it
> doesn't seem to restrict the number of digits on input.
> Here is the constraint I used, in xls forms. Can you please confirm that I
> have the correct formatting?
> regex(.,'[A-Za-z0-9]{2}')
> Thanks so much.
> Best,
> Audrey
>> > Hi Yaw,
>> > letters.
>> > whether
>> > advise
>> > Best,
>> > Audrey
>> >> Michael
>> >> long.
>> >> Hope this helps,
>> >> Yaw
>> >> > Hi ODK Community,
>> >> > respondent's
>> >> > Name
>> >> > [NAME's]
>> >> > actual
>> >> > Name
>> >> > that
>> >> > the
>> >> > 7-10
>> >> > integers
>> >> > xls?
>> >> > Michael
>> > Groups
>> > an
tested
the
letters.
whether
advise
Audrey
Michael
long.
respondent's
Name
[NAME's]
actual
Name
that
the
7-10
integers
in
MS Excel)?
default: 100000000.
I'm trying to constraints on the length of an integer field and
both regex(.,'[A-Za-z0-9]{4}') and regex(.,'^[A-Za-z0-9]{4}$'), allow
inputs more than 4 digits. Can you please let me know how I can restrict
the length to exactly 4 digits?
Pratibha
On Thursday, January 31, 2013 1:38:47 AM UTC+5:30, Audrey Henkels wrote:
> Works perfectly now. Thanks for the help!
> Best,
> Audrey
>> On Wed, Jan 30, 2013 at 11:09 AM, Audrey Henkels <audrey....@gmail.com > wrote:
>> > Hi Yaw,
>> now it
>> that I
>> > Thanks so much.
>> > Best,
>> > Audrey
>> >> On Wed, Jan 30, 2013 at 10:28 AM, <audrey....@gmail.com > wrote:
>> >> > Hi Yaw,
>> tested
>> the
>> >> > letters.
>> >> > whether
>> >> > advise
>> >> > Best,
>> >> > Audrey
>> >> >> Michael
>> >> >> long.
>> >> >> Hope this helps,
>> >> >> Yaw
>> >> >> > Hi ODK Community,
>> >> >> > respondent's
>> >> >> > Name
>> >> >> > [NAME's]
>> >> >> > actual
>> >> >> > Name
>> >> >> > that
>> >> >> > the
>> >> >> > 7-10
>> >> >> > integers
>> in
>> >> >> > xls?
>> >> >> > Michael
>> >> > Groups
>> send
>> >> > an
>> Groups
>> an
>> Groups
>> an
The alternative is to use the text data type with appearance=numbers.
It won't save the value as a number, but I think that'll let you enter
commas.
way to have number field automatically separated by comma or dot (like in MS
Excel)?
default: 100000000.
