I am trying to use an external camera app as mentioned here: https://docs.getodk.org/form-question-types/#image-widget-with-custom-camera-app. I am using exact syntax as mentioned in the example:
parameters
app=net.sourceforge.opencamera
However, on Central v2023.1, the uploading of xlsform is giving following error:
The XLSForm could not be converted: Accepted parameters are 'max-pixels'. The following are invalid parameter(s): 'app'.
Can someone help about what is wrong?
Please note that this is the problem on Central, not on ODK collect.
Many thanks for the help!
