XLSForm convertion using python command
Hello ,
I am a windows 7 64-bit user and want to transform excel sheets to xform
with a help of an offline converter . I downloaded the offline converter
windows version but for some reason i was unable to get the output in
output directory . So i tried to do it manually using the python script . i
downloaded and installed everything from this link*
https://github.com/UW-ICTD/xlsform.exe/blob/master/README.md* and installed
python and its path, tools and utils successfully . then i downloaded
pyxform from this link https://github.com/UW-ICTD/pyxform and kept the
directory in c drive on root . and they i downloaded the sample_test.xls
and kept in the pyxform directory and also created an output directory
inside pyxform directory .
I am getting this error when i am running this script in windows command
prompt .
C:\pyxform>python xls2xform.py "c:\pyxform\sample_test.xls"
"c:\pyxform\output"Traceback (most recent call last): File "xls2xform.py",
line 7, in import builder File "C:\pyxform\builder.py", line
4, in from survey import Survey File "C:\pyxform\survey.py",
line 13, in from pyxform import constantsImportError: No module
named pyxform
Please suggest .
Many Thanks,
Muhammad Ali
I think the easiest way to install pyxform is 'pip install pyxform'.
See https://github.com/SEL-Columbia/pyxform
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
On Tue, Jun 3, 2014 at 1:26 AM, Muhammad ALi malizahid52@gmail.com wrote:
Hello ,
windows version but for some reason i was unable to get the output in output
https://github.com/UW-ICTD/xlsform.exe/blob/master/README.md and installed
directory in c drive on root . and they i downloaded the sample_test.xls and
kept in the pyxform directory and also created an output directory inside
pyxform directory .
prompt .
"c:\pyxform\output"
File "xls2xform.py", line 7, in
import builder
File "C:\pyxform\builder.py", line 4, in
File "C:\pyxform\survey.py", line 13, in
ImportError: No module named pyxform
Please suggest .
Many Thanks,
Muhammad Ali
Hi Yaw ,
Thanks for your suggestion , i downloaded the pyxform through pip command .
still no luck :frowning:
anyother possibility of running the command ?
Muhammad Ali
ยทยทยท On Tuesday, June 3, 2014 1:26:34 PM UTC+5, Muhammad ALi wrote: > > Hello , > > I am a windows 7 64-bit user and want to transform excel sheets to xform > with a help of an offline converter . I downloaded the offline converter > windows version but for some reason i was unable to get the output in > output directory . So i tried to do it manually using the python script . i > downloaded and installed everything from this link* > https://github.com/UW-ICTD/xlsform.exe/blob/master/README.md > * and > installed python and its path, tools and utils successfully . then i > downloaded *pyxform* from this link *https://github.com/UW-ICTD/pyxform > * and kept the directory in c drive > on root . and they i downloaded the sample_test.xls and kept in the pyxform > directory and also created an output directory inside pyxform directory . > I am getting this error when i am running this script in windows command > prompt . > > > > > > > > > > *C:\pyxform>python xls2xform.py "c:\pyxform\sample_test.xls" > "c:\pyxform\output"Traceback (most recent call last): File "xls2xform.py", > line 7, in import builder File "C:\pyxform\builder.py", line > 4, in from survey import Survey File "C:\pyxform\survey.py", > line 13, in from pyxform import constantsImportError: No module > named pyxform* > > Please suggest . > > Many Thanks, > Muhammad Ali > > > >
Hi Yaw ,
Yes it is running . i went to python command line and typed print 'hello
world' and it is printing that in second line .
Do i need to type that command on python command line ? i was using windows
terminal to run that script ?
Thanks ,
Muhammad Ali
Muhammad,
Don't know what to tell you. There's maybe something broken with your
Python install? Or maybe something broken with Python on Windows? Does
a basic hello world python app work?
Try an Ubuntu desktop VM. Or file an issue at
https://github.com/SEL-Columbia/pyxform/issues. Or ask on
https://groups.google.com/forum/#!forum/formhub-developers.
On Tue, Jun 3, 2014 at 11:03 AM, Muhammad ALi malizahid52@gmail.com wrote:
Hi Yaw ,
Muhammad Ali
Hello ,
pyxform directory .
prompt .
"c:\pyxform\output"
import builder
Please suggest .
Many Thanks,
Muhammad Ali
This is all I have to do to get it working...
$ cd /usr/local/lib/python2.7/site-packages/pyxform;
$ python xls2xform.py ~/Desktop/Form.xlsx ~/Desktop/Form.xml;
On Tue, Jun 3, 2014 at 12:10 PM, Muhammad ALi malizahid52@gmail.com wrote:
Hi Yaw ,
Thanks ,
Muhammad Ali
Hello ,
pyxform directory .
prompt .
"c:\pyxform\output"
import builder
Please suggest .
Many Thanks,
Muhammad Ali
Hi Yaw ,
Thanks ,
Muhammad Ali
Hello ,
pyxform directory .
prompt .
"c:\pyxform\output"
import builder
Please suggest .
Many Thanks,
Muhammad Ali
Dear Muhammad
I had the same problem.
To fix, please go to survey.py, line 13 and remove "from pyxform", so the line should only read "import constants".
This worked for me and I can now convert xls to xml under Windows (7) with pyxform.
Hope this can help somebody else aswell.
ยทยทยท On Tuesday, June 3, 2014 9:26:53 PM UTC+2, Yaw Anokwa wrote: > On Tue, Jun 3, 2014 at 12:10 PM, Muhammad ALi wrote: > > On Tuesday, June 3, 2014 1:26:34 PM UTC+5, Muhammad ALi wrote: From my limited python knowledge, the import expects a file pyxform, which does not exist (at least not in my case), but with the edit it will load the file constants.py instead.
One prolem when run pyxform on version 0.9.22 is in functin def _java_installed():
which command is on linux but in window, where command is used
ยทยทยท On Tuesday, August 12, 2014 1:32:09 PM UTC+7, haarerau...@gmail.com wrote: > On Tuesday, June 3, 2014 9:26:53 PM UTC+2, Yaw Anokwa wrote: > > This is all I have to do to get it working... > > > > > > > > $ cd /usr/local/lib/python2.7/site-packages/pyxform; > > > > $ python xls2xform.py ~/Desktop/Form.xlsx ~/Desktop/Form.xml; > > > > > > > > Yaw > > > > -- > > > > Need ODK services? http://nafundi.com provides form design, server > > > > setup, professional support, and software development for ODK. > > > > > > > > On Tue, Jun 3, 2014 at 12:10 PM, Muhammad ALi wrote: > > > > > Hi Yaw , > > > > > > > > > > Yes it is running . i went to python command line and typed print 'hello > > > > > world' and it is printing that in second line . > > > > > Do i need to type that command on python command line ? i was using windows > > > > > terminal to run that script ? > > > > > > > > > > Thanks , > > > > > > > > > > Muhammad Ali > > > > > > > > > > On Tuesday, June 3, 2014 1:26:34 PM UTC+5, Muhammad ALi wrote: > > > > >> > > > > >> Hello , > > > > >> > > > > >> I am a windows 7 64-bit user and want to transform excel sheets to xform > > > > >> with a help of an offline converter . I downloaded the offline converter > > > > >> windows version but for some reason i was unable to get the output in output > > > > >> directory . So i tried to do it manually using the python script . i > > > > >> downloaded and installed everything from this link > > > > >> https://github.com/UW-ICTD/xlsform.exe/blob/master/README.md and installed > > > > >> python and its path, tools and utils successfully . then i downloaded > > > > >> pyxform from this link https://github.com/UW-ICTD/pyxform and kept the > > > > >> directory in c drive on root . and they i downloaded the sample_test.xls and > > > > >> kept in the pyxform directory and also created an output directory inside > > > > >> pyxform directory . > > > > >> I am getting this error when i am running this script in windows command > > > > >> prompt . > > > > >> > > > > >> C:\pyxform>python xls2xform.py "c:\pyxform\sample_test.xls" > > > > >> "c:\pyxform\output" > > > > >> Traceback (most recent call last): > > > > >> File "xls2xform.py", line 7, in > > > > >> import builder > > > > >> File "C:\pyxform\builder.py", line 4, in > > > > >> from survey import Survey > > > > >> File "C:\pyxform\survey.py", line 13, in > > > > >> from pyxform import constants > > > > >> ImportError: No module named pyxform > > > > >> > > > > >> Please suggest . > > > > >> > > > > >> Many Thanks, > > > > >> Muhammad Ali > > > > >> > > > > >> > > > > >> > > > > > -- > > > > > -- > > > > > Post: opendatakit@googlegroups.com > > > > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > > > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > > > > > > > --- > > > > > You received this message because you are subscribed to the Google Groups > > > > > "ODK Community" group. > > > > > To unsubscribe from this group and stop receiving emails from it, send an > > > > > email to opendatakit+unsubscribe@googlegroups.com. > > > > > For more options, visit https://groups.google.com/d/optout. > > Dear Muhammad > > I had the same problem. > > To fix, please go to survey.py, line 13 and remove "from pyxform", so the line should only read "import constants". > > From my limited python knowledge, the import expects a file pyxform, which does not exist (at least not in my case), but with the edit it will load the file constants.py instead. > > This worked for me and I can now convert xls to xml under Windows (7) with pyxform. > > Hope this can help somebody else aswell.
Another prolem is unicode for select one external. Do not support unicode
Please file bugs for pyxform at
https://github.com/xlsform/pyxform/issues. In the case of the unicode
issue, it would be great if you attached an example.
Hi Yaw ,
Thanks ,
Muhammad Ali
Hello ,
pyxform directory .
prompt .
"c:\pyxform\output"
import builder
Please suggest .
Many Thanks,
Muhammad Ali
Dear Muhammad
