When running my XLS through the XLSform converter, I get an error "Error: The survey element named 'generated_note_name_133' has no label or hint." However, I do not have any survey element with that name. In fact "generated_note_name_162" never appears in the worksheet at all.
XLSForm offline v1.6.0 and also the online version at http://opendatakit.org/xiframe/
Run the attached XLS through XLSForm converter.MERAFollowUp_xlsform_52918.xls (97.5 KB)
removed extraneous rows from the XLS, cleared formatting, filled in labels and hints where i didn't think they were needed. Also, danced naked around an upside down cross with laptop while shouting "Om Mane Padme Ohmmmm".
Form is attached.
