test.xlsx (23.0 KB)
I keep getting this message "Check your columns for errors.
There are missing symbols (like $ for relevant or calculate) or incorrect characters
Update your XLSForm and upload again."
please assist
test.xlsx (23.0 KB)
please assist
You can use XLSForm Online to check your form.
It should give you detailed errors and you can track down the problems one by one.
For example like this:
After fixing some issues with the begin group and end group rows in your form, it passes the tests on XLSForm Online and previews in Enketo.
What platform are you using that is giving you those other errors?
