Hello.
I'm trying to make Group Question with XLS:
type name label
begin group table table-list group
select_one choice table_question_1 Table list question 1
select_one choice table_question_2 Table list question 2
select_one choice table_question_3 Table list question 3
select_one choice table_question_4 Table list question 4
end group table
list_name name label
choice 1 Yes
choice 2 No
choice 3 Maybe
choice 4 Don't know
Is it possible to set different names for each question of the group?
It shoud look like:
table_question_1 - Yes=1, No=2, Maybe=3, Don't know=4
table_question_2 - Yes=5, No=6, Maybe=7, Don't know=8
table_question_3 - Yes=9, No=10, Maybe=11, Don't know=12
table_question_4 - Yes=13, No=14, Maybe=15, Don't know=16
well, i tried to use different choice lists, but with table-list group it calls an error in XLSForm:
[row : 4] Badly formatted table list, list names don't match: yes_no vs. a_b
Press Enter to continue...
since you want different names for the selections, these would be different
choice lists.
choice1to4
choice5to6
etc.
Note that the name is always a string value, so if you were to do any
calculations, you would have to convert these to numbers or integers
explicitly before doing arithmetic or integer value comparisons (e.g., "11"
> "9" is false but int("11") > int("9") is true).
On Wed, May 14, 2014 at 10:47 PM, trilomin@gmail.com wrote:
No ideas at all? =(
Ah, OK. Sorry, I overlooked the part about table-list.
Yes, you cannot do this.
a_b
