Since yesterday I have had no response from the XLSForm on the opendatakit
site (http://opendatakit.org/xiframe/). The main page loads, but not the
form itself. Are others having this problem?
Many thanks
Guy
Many thanks
Guy
Guy,
Looks like the server is down. Mitch will reboot it when he gets a chance.
Instead of the site, try XLSForm Offline: https://gumroad.com/l/xlsform-offline.
form itself. Are others having this problem?Many thanks
Guy--
The XLSForm server should be up again.
It appears to have been a target of a malicious attack.
I think I upgraded/patched the vulnerable software.
I am still running this so that when it fails, it will not reboot (so that
I can investigate causes).
As Yaw has stated, there are versions of XLSForm that you can download and
run locally. When doing that, you should also download and use the ODK
Validate tool to confirm that your generated XML document does not have
errors.
Guy,
https://gumroad.com/l/xlsform-offline.Yaw
Need ODK consultants? https://nafundi.com provides form design, server
setup, in-field training, and software development for ODK.On Mon, Oct 26, 2015 at 1:30 PM, Guy Harling guy.harling@gmail.com wrote:
opendatakit
the
Guy--
XLSForm Offline comes bundled with ODK Validate. As long as you have
Java installed, it'll validate the form automatically.
I think I upgraded/patched the vulnerable software.I am still running this so that when it fails, it will not reboot (so that I
can investigate causes).As Yaw has stated, there are versions of XLSForm that you can download and
errors.On Sun, Oct 25, 2015 at 11:32 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Guy,
opendatakit
the
Guy--
Groups
an
mitchellsundt@gmail.com--
