Hello.
I'm new to XLSForms and ODK, but I did some searching and couldn't find an answer to my question.
I'm making a form and I would like to group certain questions together, with breaks/spaces in between. However we have some technologically-unsavvy people that may use the form, and I don't want the 'collapse' functionality that goes with groups. I haven't found another way to insert a gap between survey questions.
Below is what I have currently. You can see that the "type in the name" question is not separated at all from the note (Snowball) below it. I would like to have a thick gap, maybe with a horizontal line, to separate the two. In my settings I have the style set as theme-grid because I need certain questions to be beside each other, but I hope this doesn't mean it's impossible to have gaps without using groups.
Thank you for your help.
