What are the best options for creating web-based HTML forms for XLSForms?
I'm checking Orbeon but I'm not sure if itsupports XLSForms. What are your
thoughts? Other alternatives?
Regards,
piqo
Regards,
piqo
Enketo (www.enketo.org) is your best bet!
Chris
thoughts? Other alternatives?Regards,
piqo--
+1 ![]()
I recommend checking out enketo-express
https://github.com/enketo/enketo-express first (it's a modern node.js app
built around enketo-core). If this app does not meet your needs or you need
to integrate with another platform, it will at least provide an example of
the architecture of a minimal app that uses the client-side enketo-core
https://github.com/enketo/enketo-core library.
Cheers,
Martijn
