XLSForm trouble
I am in a trouble to deploy the XLSForm
Kobo Toolbox server shows error while trying to upload & deployed in the server. Server shows as follows :
your form cannot be deployed because it contains errors:
ODK Validate Errors: >> Something broke the parser. See above for a hint. Error evaluating field 'education': Can't set data value for node that has children! Caused by: java.lang.RuntimeException: Can't set data value for node that has children! ... 10 more Result: Invalid
Please help me to resolute this problem ..
It would be easier for forum member to solve your problem if you could attach your XLSForm here.
Adolescent Registration Form-MPC.xls (45 KB)
Waiting for your kind support
Line 44, your begin group has a garbage calculation value = "'vpMwjoJ2yKKL8ge79Rjk37`"
If you remove this it should parse fine.
Adolescent Registration Form-MPC.xls (44.5 KB)
Can u please help me to remove that ..
check this file Adolescent Registration Form-MPC.xls (54 KB)
Thanks a lot .. :slightly_smiling_face:
