I'm trying to do the following use case:-
Question 1:
Do you have an apple?
Option 1: Yes
Option 2: No
If yes, then show the following questions:-
Question 1 (a):
What is the weight of an apple?
Integer
Question 1 (b):
What is the false weight of an apple?
Integer
Question 1 (c)
Calculation = Q1(a) - Q1(c)
Question 2:
Do you have a banana?
Option 1: Yes
Option 2: No
Question 2 (a):
What is the weight of a banana?
Integer <value should be Q1(c)>
Question 2 (b):
What is the false weight of a banana?
Integer
Question 2 (c)
Calculation = Q2(a) - Q2(c)
Question 3:
Do you have an orange?
Option 1: Yes
Option 2: No
If no, then skip to question 4
Question 4:
Do you have mangoes?
Option 1: Yes
Option 2: No
Question 4 (a):
What is the weight of mangoes?
Integer <value should be Q2(c)>
Question 4 (b):
What is the false weight of mangoes?
Integer
Question 4 (c)
Calculation = Q4(a) - Q4(c)
