XLSX Converter: TypeError: Cannot read property 'length' of undefined
Hi all,
I am a first time ODK Survey user.
I have installed ODK Application Designer 2.0 Alpha-1.
After launching ODK Application Designer , I used XLSX Converter to
generate a formDef.json file from my XLSX file.
I received following error:
What this error message is about/ is the reason & solution for it?
Pradnya
We will need your XLSX file to debug this. There are no errors that we
generate with this error.
··· On Wed, May 21, 2014 at 2:18 AM, Pradnya wrote:
Hi all,
Pradnya
Hi Mitch,
Thanks for the reply.
I was able to get rid of that error.
I am trying to convert an excel file that uses "XLSForm" format to ODK
Survey compatible format. In the process I received that error.
Now I am getting different error:
Error: Unrecognized prompt type. Prompt: 'begin group' at row 20 on sheet:
survey
Basically there is "begin group" and "end group" and this is not valid in
ODK Survey.
I am struggling to find equivalent concept in ODK Survey
I have attached the excel file
Any help is appreciated
Thanks again
Pradnya
FDSurvey1.xlsx (25.7 KB)
··· On Wednesday, May 21, 2014 7:02:53 PM UTC+2, Mitch Sundt wrote: > > We will need your XLSX file to debug this. There are no errors that we > generate with this error. > > > > On Wed, May 21, 2014 at 2:18 AM, Pradnya <pska...@gmail.com >wrote: > >> Hi all, >> I am a first time ODK Survey user. >> I have installed ODK Application Designer 2.0 Alpha-1. >> After launching ODK Application Designer , I used XLSX Converter to >> generate a formDef.json file from my XLSX file. >> I received following error: >> *TypeError: Cannot read property 'length' of undefined* >> What this error message is about/ is the reason & solution for it? >> >> Thanks >> Pradnya >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >
Thank you for trying this out. ODK Survey does not have the concept of
groups. It has two related concepts:
(1) screens -- begin screen ... end screen -- these are equivalent to a
group with a field-list appearance. The 'begin screen' and 'end screen' go
in the 'clause' column, not in the 'type' column.
Screens control the layout of a set of questions on a page. Different
screen types can alter the layout mechanisms, including a custom layout
that uses an arbitrary HTML template for field placements.
(2) sections -- these are additional tabs containing subsets of survey
questions (using the same column headings / format as the 'survey' sheet).
Sections are very simple groupings of related questions. You transition
into section 'mysection' via 'do section mysection', which starts at the
top of that sheet. Sections can be exited via 'exit section'. These
statements are placed in the 'clause' column.
··· On Mon, May 26, 2014 at 4:49 AM, Pradnya wrote:
Hi Mitch,
survey
ODK Survey.
Thanks again
Pradnya
On Wed, May 21, 2014 at 2:18 AM, Pradnya pska...@gmail.com wrote:
Hi all,
Pradnya
Groups "ODK Community" group.
mitche...@gmail.com
Thank you very much for your response
I will try out these concepts
regards
Pradnya
··· On Tuesday, May 27, 2014 6:28:31 PM UTC+2, Mitch Sundt wrote: > > Thank you for trying this out. ODK Survey does not have the concept of > groups. It has two related concepts: > > (1) screens -- begin screen ... end screen -- these are equivalent to a > group with a field-list appearance. The 'begin screen' and 'end screen' go > in the 'clause' column, not in the 'type' column. > > Screens control the layout of a set of questions on a page. Different > screen types can alter the layout mechanisms, including a custom layout > that uses an arbitrary HTML template for field placements. > > (2) sections -- these are additional tabs containing subsets of survey > questions (using the same column headings / format as the 'survey' sheet). > > Sections are very simple groupings of related questions. You transition > into section 'mysection' via 'do section mysection', which starts at the > top of that sheet. Sections can be exited via 'exit section'. These > statements are placed in the 'clause' column. > > > > On Mon, May 26, 2014 at 4:49 AM, Pradnya <pska...@gmail.com > wrote: > >> >> Hi Mitch, >> Thanks for the reply. >> I was able to get rid of that error. >> I am trying to convert an excel file that uses "XLSForm" format to ODK >> Survey compatible format. In the process I received that error. >> >> Now I am getting different error: >> Error: Unrecognized prompt type. Prompt: 'begin group' at row 20 on >> sheet: survey >> >> Basically there is "begin group" and "end group" and this is not valid in >> ODK Survey. >> I am struggling to find equivalent concept in ODK Survey >> I have attached the excel file >> >> Any help is appreciated >> Thanks again >> Pradnya >> >> On Wednesday, May 21, 2014 7:02:53 PM UTC+2, Mitch Sundt wrote: >> >>> We will need your XLSX file to debug this. There are no errors that we >>> generate with this error. >>> >>> >>> >>> On Wed, May 21, 2014 at 2:18 AM, Pradnya wrote: >>> >>>> Hi all, >>>> I am a first time ODK Survey user. >>>> I have installed ODK Application Designer 2.0 Alpha-1. >>>> After launching ODK Application Designer , I used XLSX Converter to >>>> generate a formDef.json file from my XLSX file. >>>> I received following error: >>>> *TypeError: Cannot read property 'length' of undefined* >>>> What this error message is about/ is the reason & solution for it? >>>> >>>> Thanks >>>> Pradnya >>>> >>>> -- >>>> -- >>>> Post: opend...@googlegroups.com >>>> Unsubscribe: opendatakit...@googlegroups.com >>>> >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>> >>>> --- >>>> You received this message because you are subscribed to the Google >>>> Groups "ODK Community" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to opendatakit...@googlegroups.com. >>>> >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> >>> >>> -- >>> Mitch Sundt >>> Software Engineer >>> University of Washington >>> mitche...@gmail.com >>> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >
Could you tell me how you resolved the problem regarding the error:
Thanks.
segunda-feira, 2 de Junho de 2014 às 09:32:13 UTC+1, Pradnya escreveu:
··· > Thank you very much for your response > I will try out these concepts > > > > > regards > Pradnya > > On Tuesday, May 27, 2014 6:28:31 PM UTC+2, Mitch Sundt wrote: > > > Thank you for trying this out. ODK Survey does not have the concept of groups. It has two related concepts: > > (1) screens -- begin screen ... end screen -- these are equivalent to a group with a field-list appearance. The 'begin screen' and 'end screen' go in the 'clause' column, not in the 'type' column. > > > Screens control the layout of a set of questions on a page. Different screen types can alter the layout mechanisms, including a custom layout that uses an arbitrary HTML template for field placements. > > > > > (2) sections -- these are additional tabs containing subsets of survey questions (using the same column headings / format as the 'survey' sheet). > > > Sections are very simple groupings of related questions. You transition into section 'mysection' via 'do section mysection', which starts at the top of that sheet. Sections can be exited via 'exit section'. These statements are placed in the 'clause' column. > > > > > > > On Mon, May 26, 2014 at 4:49 AM, Pradnya wrote: > > > > Hi Mitch, > Thanks for the reply. > I was able to get rid of that error. > I am trying to convert an excel file that uses "XLSForm" format to ODK Survey compatible format. In the process I received that error. > > > > Now I am getting different error: > Error: Unrecognized prompt type. Prompt: 'begin group' at row 20 on sheet: survey > > > > Basically there is "begin group" and "end group" and this is not valid in ODK Survey. > I am struggling to find equivalent concept in ODK Survey > I have attached the excel file > > > > Any help is appreciated > Thanks again > Pradnya > > > > On Wednesday, May 21, 2014 7:02:53 PM UTC+2, Mitch Sundt wrote: > > > We will need your XLSX file to debug this. There are no errors that we generate with this error. > > > > > > > On Wed, May 21, 2014 at 2:18 AM, Pradnya wrote: > > > > > Hi all, > I am a first time ODK Survey user. > I have installed ODK Application Designer 2.0 Alpha-1. > > > After launching ODK Application Designer , I used XLSX Converter to generate a formDef.json file from my XLSX file. > I received following error: > TypeError: Cannot read property 'length' of undefined > > > > What this error message is about/ is the reason & solution for it? > > > > Thanks > > Pradnya > > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google Groups "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com. > > > For more options, visit https://groups.google.com/d/optout. > > > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com > > > > > > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google Groups "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com. > > For more options, visit https://groups.google.com/d/optout. > > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com
Without the form producing the error, no.
Thanks.
regards
Pradnya
On Mon, May 26, 2014 at 4:49 AM, Pradnya pska...@gmail.com wrote:
Hi Mitch,
sheet: survey
in ODK Survey.
Thanks again
Pradnya
Hi all,
Pradnya
mitche...@gmail.com
mitche...@gmail.com
I've sent the xlsx form attached in this message, is something wrong with the file?
Thank you.
quarta-feira, 25 de Fevereiro de 2015 às 18:40:27 UTC, Mitch Sundt escreveu:
tableId.xlsx (9.68 KB)
··· > Without the form producing the error, no. > > > > On Wed, Feb 25, 2015 at 8:18 AM, wrote: > Could you tell me how you resolved the problem regarding the error: > > > > TypeError: Cannot read property 'length' of undefined > > > > Thanks. > > > > > > segunda-feira, 2 de Junho de 2014 às 09:32:13 UTC+1, Pradnya escreveu: > > > > > Thank you very much for your response > > > I will try out these concepts > > > > > > > > > > > > > > > regards > > > Pradnya > > > > > > On Tuesday, May 27, 2014 6:28:31 PM UTC+2, Mitch Sundt wrote: > > > > > > > > > Thank you for trying this out. ODK Survey does not have the concept of groups. It has two related concepts: > > > > > > (1) screens -- begin screen ... end screen -- these are equivalent to a group with a field-list appearance. The 'begin screen' and 'end screen' go in the 'clause' column, not in the 'type' column. > > > > > > > > > Screens control the layout of a set of questions on a page. Different screen types can alter the layout mechanisms, including a custom layout that uses an arbitrary HTML template for field placements. > > > > > > > > > > > > > > > (2) sections -- these are additional tabs containing subsets of survey questions (using the same column headings / format as the 'survey' sheet). > > > > > > > > > Sections are very simple groupings of related questions. You transition into section 'mysection' via 'do section mysection', which starts at the top of that sheet. Sections can be exited via 'exit section'. These statements are placed in the 'clause' column. > > > > > > > > > > > > > > > > > > > > > On Mon, May 26, 2014 at 4:49 AM, Pradnya wrote: > > > > > > > > > > > > Hi Mitch, > > > Thanks for the reply. > > > I was able to get rid of that error. > > > I am trying to convert an excel file that uses "XLSForm" format to ODK Survey compatible format. In the process I received that error. > > > > > > > > > > > > Now I am getting different error: > > > Error: Unrecognized prompt type. Prompt: 'begin group' at row 20 on sheet: survey > > > > > > > > > > > > Basically there is "begin group" and "end group" and this is not valid in ODK Survey. > > > I am struggling to find equivalent concept in ODK Survey > > > I have attached the excel file > > > > > > > > > > > > Any help is appreciated > > > Thanks again > > > Pradnya > > > > > > > > > > > > On Wednesday, May 21, 2014 7:02:53 PM UTC+2, Mitch Sundt wrote: > > > > > > > > > We will need your XLSX file to debug this. There are no errors that we generate with this error. > > > > > > > > > > > > > > > > > > > > > On Wed, May 21, 2014 at 2:18 AM, Pradnya wrote: > > > > > > > > > > > > > > > Hi all, > > > I am a first time ODK Survey user. > > > I have installed ODK Application Designer 2.0 Alpha-1. > > > > > > > > > After launching ODK Application Designer , I used XLSX Converter to generate a formDef.json file from my XLSX file. > > > I received following error: > > > TypeError: Cannot read property 'length' of undefined > > > > > > > > > > > > What this error message is about/ is the reason & solution for it? > > > > > > > > > > > > Thanks > > > > > > Pradnya > > > > > > > > > > > > > > > -- > > > > > > -- > > > > > > Post: opend...@googlegroups.com > > > > > > Unsubscribe: opendatakit...@googlegroups.com > > > > > > > > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > > > > > > > > > --- > > > > > > You received this message because you are subscribed to the Google Groups "ODK Community" group. > > > > > > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com. > > > > > > > > > For more options, visit https://groups.google.com/d/optout. > > > > > > > > > > > > > > > > > > -- > > > Mitch Sundt > > > Software Engineer > > > University of Washington > > > mitche...@gmail.com > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > -- > > > > > > Post: opend...@googlegroups.com > > > > > > Unsubscribe: opendatakit...@googlegroups.com > > > > > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > > > > > > > > > --- > > > > > > You received this message because you are subscribed to the Google Groups "ODK Community" group. > > > > > > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com. > > > > > > For more options, visit https://groups.google.com/d/optout. > > > > > > > > > > > > > > > -- > > > Mitch Sundt > > > Software Engineer > > > University of Washington > > > mitche...@gmail.com > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google Groups "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com. > > For more options, visit https://groups.google.com/d/optout. > > > > > -- > > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com
The column headings need to be lower case.
Change:
Condition on the survey sheet.
Value on the settings sheet.
the file?
Thank you.
escreveu:
Thanks.
regards
Pradnya
Hi Mitch,
sheet: survey
in ODK Survey.
Thanks again
Pradnya
Hi all,
Pradnya
mitche...@gmail.com
mitche...@gmail.com
mitche...@gmail.com
