Are ODK entities able to now work offline?
As of Central v2024.3 and Collect v2024.3, you can use Entities offline.
Thanks for the response . So i have a form that i use to generate new IDS to participants. For every new participant, the previous ID is incremented by 1 to generate the new ID
The challenge i have is the calculation to generate this ID looks at an already uploaded excel to determine the previous assigned ID. I was thinking of using entities to update this uploaded excel in real time since in the field we usually work on 3 participants or more at a go .
can entities help with this?
Yes, Entity Lists should be a great fit for this! The general concept would be to look up some existing number like the biggest id assigned so far and add 1 to that.
I think you'll find this thread helpful: Generate sequential ID based on pulled data - #6 by LN
Hello, thanks for the help on this . I have tried to implement this and yes the entities are being created however, the challenge is i want to update existing entities but not creating new ones.Below is a screenshot showing my entities and you can clearly see that it creates new ones other than updating existing entities. i have also uploaded my xls form
TRYD.xlsx (586.1 KB)
Hi @Terry_Ongaria,
In order to update entities, you need to change your form design. You could add another form so you have your existing form for creating entities and a new form for updating those entities.
Here is some more information on updating entities. Also check out the Entity Quick Reference.
If you want to see a form that both creates and updates entities, please check out this forum post.
Hi @ktuite , thanks for the quick response on this . I have looked through the links and yes i have got some info on how to go about it , however, i am still facing challenges. Attached is my entity list that i uploaded to centra
idlist2.csv (113.1 KB)
l. I have two fields num and vno . I want the num column to be the only one updated hence i do not need creation of new entities . My first question is whether my entity list is ok?, do i need to add any new columns
This CSV can become an entity list with two properties num and vno_hno.
You also need another column in your CSV called label because every entity needs a label. I suggest just duplicating the vno_hno column OR using a dummy value that is the same for each row.
(The labels don't have to be unique. They are used for displaying entities in forms, but from what you've said about your form, you might not ever display it?)
Entities also have an Entity ID (also called name) but Central will generate an ID for every row when you upload the CSV. This is the ID you would need to work with in your form. You would select the entity based on the vno_hno value and then get the name of that entity. Then you should be able to just update the num property of that entity! This part of the Entity Quick Reference has an example: Looking up an Entity from an External CSV
If you share a sample form with me, I can try to help more.
Thanks @ktuite . I have gone ahead and added a label column ,since i am not particularly interested in it, i have just assigned it random values .
I think now the only challenge is working with the entity ID , i seem to be unable to reference it from my entities sheet, i would be grateful if you can assist on this particular step. Attached below is a copy of my form and the the new entity list. I have also attached another csv pinfo which isn't necessary for the entities but which you might need when uploading the main xlsx form.
Copy of ODK XLSForm Template.xlsx (586.1 KB)
Test1.csv (192.5 KB)
pinfo.csv (2.4 MB)
Hi @Terry_Ongaria
Sorry it took so long to get back to you! Thank you for sharing the forms and data.
My understanding of your problem: You need to assign sequential IDs (within a village and household) so you are using entities to keep track of the current count of people in a household and use that count as part of generating the new ID. The vno_hno field is basically the primary key of your count data.
Your form was really close to working! New version:
update_vno_hno_entities.xlsx (241.5 KB)
Here is what I did to get this the entity ID and update the num value:
  1. On the survey sheet, I added this calculate to get the Entity ID (the entity ID is stored as "name" when entities are used in forms as CSV attachments with pulldata).
type name label calculation
calculate vno_hno_entity_id pulldata('Test1', 'name', 'vno_hno', concat(${vno}, '-', ${hno_padded}))
  1. On the entities sheet, the entity_id cell needs the ${vno_hno_entity_id} from the previous calculate. In this one case where the entity is just being updated, the label can be blank.
list_name label entity_id
Test1 ${vno_hno_entity_id}
  1. For the Entity List on Central, I made sure that the Entity List had 2 properties, num and vno_hno. Then I was able to upload the CSV you provided with the label column.
If you look at the Entities in Central or even download them, you will see the ID column with a random UUID like "1ab2f005-2556-4dbf-9afb-df88238856db" and this is what was needed to connect the updates in the form. (Though remember, when using this in a form, this entity ID is called name!)
Thanks @ktuite for the detailed response , much appreciated!. I have tried to replicate your form following all the steps but still cant seem to update the entities, i have attached a screenshot. Just wondering whether i could have skipped something
