Building a table or matrix for a set of questions on XLSForm
I have been trying to build a table/matrix of questions on XLSForm and have been unable to find a way to do this other than repeating groups numerous times which is not convenient and presentable. What I am hoping to build is a table with a few questions on the rows and then on the columns, answers to those questions at different points in time (now, 12 months, ago, 24 months ago). (see attached image file).
I found the below thread on the topic, but there was no response in the end on how the table can be developed on XLSform. https://groups.google.com/forum/#!searchin/opendatakit/matrix|sort:date/opendatakit/uCOF57M06xk/mELmx_YOAwAJ
XLSForm (CommCare)
-grouping and then repeating groups
Hi @sohashami
unfortunately, it's not possible in ODK Collect. I had worked on TaroWorks (a project which uses ODK Collet) before I started working on ODK Collect and one of my last features I implemented for them was TableView - you can look here for a presentation https://youtu.be/NFgExDUlK_c?t=15m9s. Overall it would be possible to implement but it would be useful on bigger screens only, not cell phones (what is ok I think) and probably there would be a problem with supporting all widgets (but in your case it's only String/Number widget so maybe we could start with that basic widgets).
I don't know if a similar proposal exists here https://forum.getodk.org/c/features if not you can create a new topic and describe your needs - maybe we can do that in the future.
Regards,
Grzegorz
Hi Grzegorz,
Thank you for your prompt response and assistance. I was afraid this may not be an option on ODK Collect, so we might just stick with repeat groups in that case for now. I'll check out the threads in the link you
sent and will post something on the forum to hopefully get this developed in the future.
Thanks!
Soha
Just want to clarify for others like myself who was struggling to understand how you can do that. Found this on Matrix fields
In order to create table/matrix of questions "Just create a group that contains the select one questions that share the same choices and apply the table-list under
appearance column in the begin group row."
Your are right. But it also work for multiple select type question.
