Connection Issues with ODK1 tools
I'm having connection issues using Build and Briefcase. I am able to build a form using the web version, upload it to sandbox and able to pull all the form options from sandbox. Briefcase is not able to fetch the selected form. (Pic3)
Online Build version on Opera 55.0
Briefcase version 1.11.3 jar on iMac, macOS High Sierra version 10.13.6
A connection issue exists also when I use the Build app (version 54.2840.99 ) on the iMac. It is not able to connect to sandbox. Login credentials are the same for both web version (Pic1) and desktop version. (Pic2).
Uploading completed forms to sandbox using Collect is also an issue (Not found 404) but one thing at a time.
Pic1
Pic2
BriefcaseLog.pdf (29.6 KB)
Hi @hc02ca, the Briefcase log says something peculiar.
Parsing URL https://sandbox.aggregate.opendatakit.org/formXml?formId=build_Sample1HC_15 36360341
2018-09-07 18:47:39,734 [pool-2-thread-1] ERROR o.o.briefcase.util.ServerFetcher - error accessing form download URL org.apache.http.conn.HttpHostConnectException: Connect to 127.0.0.1:8081 [/127.0.0.1] failed: Connection refused (Connection refused)
It seems like you might be behind a proxy.
It's trying to connect to https://sandbox.aggregate.opendatakit.org but it reports the as 127.0.0.1:8081. Is it possible you are on a network that requires device first log into a website (e.g., at a coffee shop) or your network connection is proxied?
I'm not at a coffee shop so my network connection must be proxied. I have to log into my iMac with my user account and password before I get to the desktop. I followed this link to bypass the proxy server by adding the sandbox option on the bottom?
https://support.apple.com/en-ca/guide/mac-help/enter-proxy-server-settings-mchlp2591/mac
Briefcase is still having troubles pulling the forms.
Thanks again!
Independent of if you are at a coffee shop, you may or may not be on proxy. Can you go to your command line (Terminal.app) and run the following and report what you find.
curl -i --header "X-OpenRosa-Version: 1.0" https://sandbox.aggregate.opendatakit.org/formList
Terminal Saved Output.txt (2.1 KB)
Great! And now can you run it with the proxy bypass removed from your settings?
I took the sandbox option off the bottom and it still doesn't work.
briefcaselog.txt (6.3 KB)
With the bypass removed, run the curl command.
Terminal Saved Output2.txt (2.1 KB)
Thanks for the debugging help, @hc02ca. I'm kinda stumped.
@ggalmazor do you have any ideas what is going wrong here?
Hi, @hc02ca!
Could you take a look to the /etc/hosts file, in case there's a line defining the IP address for sandbox.aggregate.opendatakit.org, please?
Is this is?
30%20PM
Hi, @hc02ca!
Sorry, your message took me just while I was getting on bed.
The hosts file is OK.
I'm as lost as @yanokwa.
This scenario leads me to believe that something in yout computer's networking configuration or on the network you're on is wrong.
  • Are you running any networking app like or using a VPN?
  • Could you try a wired connection or change to another WiFi network?
  • Could you open a browser and try opening http://127.0.0.1:8081 and https://127.0.0.1:8081 and see what's there?
ggalmazor https://forum.getodk.org/u/ggalmazor Guillermo
September 14
Hi, @hc02ca https://forum.getodk.org/u/hc02ca!
I'm as lost as @yanokwa https://forum.getodk.org/u/yanokwa.
Visit Topic
https://forum.getodk.org/t/connection-issues-with-odk1-tools/15061/13
or reply to this email to respond.
To unsubscribe from these emails, click here
https://forum.getodk.org/email/unsubscribe/dd49dd1f5fa2b224e4751afeb289a57636fd4db22341d241ced27ab98741d9b6
briefcaselog1.txt (3.13 KB)
briefcaselog2.txt (3.13 KB)
It doesn't look like you received Response.doc. Here it is again, parsed into smaller chunks, parts 1 - 4.
ResponsePart1.doc (354 KB)
ReponsePart2.doc (407 KB)
ResponsePart3.doc (92.5 KB)
ResponsePart4.doc (396 KB)
It appears that any app you've tried in your computer can't access the sandbox. The online Build app doesn't count because it's not your computer that connects to the sandbox, but the server where Build is running.
All leads are pointing to a networking issue in your computer, not related to ODK.
Did you try to use a wired connection or any other WiFi connection?
Sorry, here is the information again better organized.
No, I'm not running any of that.
With my wired network, build online successfully uploads a form to sandbox.
With my wired network, build app fails to upload a form to sandbox.
With my wired network, briefcase app fails to fetch a form from sandbox. See briefcaselog1.txt
briefcaselog1.txt (3.1 KB)
With a friend's wireless network, build online successfully uploads a form to sandbox.
With a friend's wireless network, build app fails to upload a form to sandbox.
With a friend's wireless network, briefcase app fails to fetch a form from sandbox. See briefcaselog2.txt
briefcaselog2.txt (3.1 KB)
With my wireless network, http://127.01.0.1:8081 gives a "This site can't be reached" page.
With my wireless network, https://127.01.01:8081 gives a "This site can't be reached" page.
With my wired network, http://127.01.0.1:8081 gives a "This site can't be reached" page.
With my wired network, https://127.01.01:8081 gives a "This site can't be reached" page.
With a friend's wireless network, http://127.01.0.1:8081 gives a "This site can't be reached" page.
With a friend's wireless network, https://127.01.01:8081 gives a "This site can't be reached" page.
All the pages give the same picture.
With any of the networks including the public library's network, the Collect app failed to upload a finalized form to sandbox. They all gave the same 404 error.
Thanks for the info, @hc02ca!
Did you use the same computer for all those tests? Can you use a different computer?
Yes, I used the same computer, my iMac and I used the same android phone.
I will get back to you in a few days with the results from a PC most likely on these networks.
Hi @ggalmazor,
Here are the results with my friend's PC using the same networks as before. I was not able to borrow her PC to test with my network.
No, she is not running anything like that to her knowledge.
With a friend's wireless network with her PC, build online successfully uploads a form to sandbox.
With a friend's wireless network with her PC, build app falls to install due to nw_elf.dll file not found. See Pic1. The file appears to be there though. See Pic2. I tried to reinstall the program but it gave the same error. I tried both the x64 and x86 version.
With a friend's wireless network with her PC, briefcase app successfully fetches the selected form. See briefcaselog3.txt
briefcaselog3.txt (3.4 KB)
With a friend's wireless network with her PC, http://127.0.0.1:8081 gives "Can't reach this page"
With a friend's wireless network with her PC, htps://127.0.0.1:8081 gives "Can't reach this page"
