Digital scale integration inquiry for traceability
Hi all would love to hear your thoughts and experiences! We are exploring the possibility of integrating digital scales with ODK Collect/aggregate to enhance the traceability of coffee throughout the supply chain. Your insights and recommendations are invaluable in helping us determine the feasibility and effectiveness of this. A search on the forum did not show any examples. Has anyone done this before? If so, Does ODK Collect support capture of external sensor data? Are specific widgets or plugins available for integrating with scales? If not, any ideas on the feasibility of using third-party apps or plugins that can communicate with the scale and send data to ODK Collect? Manny thanks in advance, Jelle
@Jellow Collect supports capture of external sensor data through the external app widget. That's how we support use-cases like fingerprint scanning and reading rapid diagnostic tests. You will have to build that external app though.
Some Bluetooth enabled devices (e.g., digital calipers, custom barcode scanners) can pretend to be Bluetooth keyboards and "type" the value that they capture. In that case a simple number widget will work just great. No additional software development needed.
If the above ideas won't work, you could also take a picture of the scale and use on-device on on-server vision recognition to read the value and add it, along with the picture, to the submission. We've done something similar with audio transcriptions.
Tell us more about the end-to-end workflow you want to support and why capturing weight is important. What problem would having this capability solve?
Would you be able to share your experience if you have successfully implemented the Bluetooth-enabled digital scale with ODK, including any pitfalls or challenges encountered?
Hi Chun in the end we decided to go with the low-tech solution of reading and then typing in the app; best jelle
