Does drop-down feature available on ODK v1.16.2.
Detail of the problem: So for a multiple choice question, i have an option "others" in the choice list and on selecting the "other" choice field the enumerator has to swipe-forward to specify the "other" choice field. But i wanted to know if it is possible to have the "please specify" field appear upon selecting the "other" choice field on the same screen. What ODK tool and version are you using? And on what device and operating system version?
yes can't include the feature that i was looking for in ODK. it seems it dosen't support. but have used the logic "selected(., '7') and count-selected<=7" to display the "please specify other" choice field on the next screen. 7 here corresponds to "please specify other."
If you think have a compelling use case, feel free to open a feature request in the Features forum to add open selection support to ODK. This would require changes in both Collect, and any form builders and associated tools; ie Build, KoboToolbox, pyxform, ... So although in-of-itself not technically challenging, it would likely be a non-trivial piece of work to support everywhere it needs to be.
Open selection is also hard to implement. We've had an issue on this for years at https://github.com/opendatakit/javarosa/issues/128. I have a sneaky suspicion that there might be code lurking in some of the JavaRosa forks that would enable this. Maybe @LN knows...
