When I update the number of iterations of a dynamic repeating group, the number of repetitions in the group only changes if the updated number is higher than the one previously entered. Otherwise, the number of iterations remains fixed at the highest value previously entered.
Server: KoboToolbox (2020-06-27)
App: ODK Collect v1.27.2
Create a XLSform with a integer input and a dynamic repeat group based on this integer. Run it with a X number of repetitions, go back and change the number of repetitions to a value < X. Finally, check the dynamic repeat group once again.
You can check it through this XLSform: repgroup-test.xlsx (10.4 KB)
