Enketo Load Error
Hi everyone, I have tried to install ODK central on my ubuntu server. I used a domain from FreeDNS and on the instance is up. The issue is when i try to preview the form after uploading it. Kindly attached is the screenshot of the pop-up error below.
I have tried to disable the firewall but still not working
The below thread is about the same error message "Client network disconnected before secure TLS connection was established"
You might check using https://mxtoolbox.com/SuperTool.aspx to see if your domain name maps to an IP. Did you add an A record mapping the domain name to your server's IP? If you've already made that mapping, you may have to wait up to a day for that change to spread across the Internet.
@danbjoseph Thanks for your feedback. Yes I had added "A record mapping to the domain name" the issue was with the .env configuration, so I changed SSL_TYPE to "letsencrypt" and that sorted out. Initialy i was using SSL_TYPE=upstream.
