Error Repeating Results
Hello, I have a problem generating the results obtained in ODK. My problem is in using repetition, because it has error in the spreadsheet (table), generating another spreadsheet with only repetition data.
I use ODK V1.23.3 and google drive.
Archive: Parcela_teste (1).xlsx (12.3 KB)
Hi @Eduardo_Segatto
Welcome to the Forum!
When you have time please introduce yourself here.
I took a look at the attachment you shared and it looks fine (no error).
The confusion might arise from the fact that you see two sheets rather than one.
I think this is the expected behavior.
The reason is that variables included in repeat groups are captured in separate tables/sheets (one per loop). In order to consolidate the observations you can merge the data 1:N using the field KEY and PARENT_KEY respectively.
"ODK Briefcase will export a set of CSV files, one for each repeating group."
Reference:
https://docs.opendatakit.org/aggregate-data-access/#csv-comma-separated-values
the logic is now replicated in Google Sheets.
Forum post in which the feature was discussed:
I hope this helps!
Andrea
