We are looking to hire someone who can help us solve the following problem that XLSForma throws at us when testing it in https://getodk.org/xlsform/ and that also does not allow us to implement it in KOBO.
Error: ODK Validate Errors:
Something broke the parser. See above for a hint.
Error evaluating field 'sumapicos_c' (${grupo_gnral}[1]/grupo_correcion[1]/repeat_correccion[1]/pulverizacion_c[1]/repeat_seccion_c[1]/sumapicos_c[1]):
The problem was located in Calculate expression for ${sumapicos_c}
XPath evaluation: type mismatch indexed-repeat(): parameter 2 must be a parent of the field in parameter 1
Caused by: org.javarosa.xpath.XPathTypeMismatchException: The problem was located in Calculate expression for ${sumapicos_c}
XPath evaluation: type mismatch indexed-repeat(): parameter 2 must be a parent of the field in parameter 1 ... 10 more
The following files failed validation: ${PRUEBA_1_2v2_REM_PULVERIZADORA_V27_SIN} EMAIL_v4.xml
Result: Invalid
PRUEBA_1_2v2_REM_PULVERIZADORA_V27_SIN EMAIL_v5.xlsx (588.5 KB)
I leave my data
Thank you very much
Alvaro
asassano@scanterra.com
