Is there any way of auto extracting the location (address) from the selected location (orange box) on the map to fill-up the next question which is asking for the address (red box)
2. Upload any test forms or screenshots below.
Thank you in advance.
You can do it after the data has been submitted but not inside the form, see this post
The term you are looking for is "geocoding" and there's no turnkey way to do this. But once the data is on the ODK server, you can build an integration to convert those coordinates to addresses in a downstream tool.
If, for example, you are using ODK's Power BI or R integration, you can send the GPS coordinates to a geocoding service (e.g., Google's Geocoding API ) and get back an address. Watch this video to learn how to geocode in Power BI and read this page to do it in R.
Related: Add geocod…
