Geopoint recodrs in degree decimal format
Hi there,
I am adding geopoint question type in my survey form. The data I obtain is in decimal seconds format. I was wondering if I can directly get the information in degree decimal format? Is there a widget or a different question type that I should use?
Yogita
Hey @yogita_karpate ,
If you can share your ODK form then it will be a great help for us. However, you can follow this link to make Geolocaton-type questions.
https://docs.getodk.org/form-question-types/#location-widgets
@iamnarendrasingh
Related thread: Syntax of the display of location data
You can compute it and display it in a field list so it's on the same screen. If you think it's critical for Collect or the form definition to be configurable in this way, please comment on that feature request thread.
