Since 2016 we have been using geopoint and when the GPS accuracy dropped below 5 m the auto save functionality worked. For the last two or three months our GPS accuracy here in Nepal won't seem to drop below 10 m now. Based on the XLS Form documentation we have tried to use body::accuracyThreshold and set this to 11 m, but the XLS Form Converter gives a warning when we try and convert the XLS sheet to an XML file.
ODK Collect v1.13.2 on an Android v7.0.
The error message above was created by converting the sample gps_accuracy_threshold Google Sheet, saving it as an XLS file, and then loading it to the xiForm converter.
We tried using only accuracyThreshold in the XLS file instead of body::accuracyThreshold. This allows the XLS file to be successfully converted to an XML, but the auto save functionality doesn't work.
It would be good to know if there was some change in the code for determining the GPS accuracy which would explain why we have observed a sudden change in its behavior.
