I want to create "If other specify" option on choose one option of question
types. How can I do that on ODK? I don't understand following statement
given on the Staging Build Tool
- To create a freeform "Other" option, add one here, then follow it up
with a Text question with the Relevance property set to reference this
question; for example: ${/xpath/to/this/choose/one} = 'other'
Hello ,
If i understand your question correctly, you can and or_other at the end of the type column on the survey sheet, for example select_one roof_c or_other
On Friday, April 21, 2017 at 3:56:38 PM UTC+3, Minilik Tesfaye wrote:
> I want to create "If other specify" option on choose one option of question types. How can I do that on ODK? I don't understand following statement given on the Staging Build Tool
> To create a freeform "Other" option, add one here, then follow it up with a Text question with the Relevance property set to reference this question; for example: ${/xpath/to/this/choose/one} = 'other'
Thank you Kiflu. But I wanted the other option where you create a text box
and collect data if "other" is selected. I noticed that it is done by
selected(${question_name},'value')
but this does not show the text box exactly when you click on the desired
option form the select_one question.
Thanks again.
> Hello ,
> or_other
> Best,
Thanks again.
> Hello ,
> or_other
> Best,
Moving to the community list because this isn't really a developer question.
Minilik,
It looks like you are using Build, and not XLSForm, so I don't think
kiflut2002's answer is relevant. I've attached an example form that
you can load into Build that shows how to use relevance to show a text
box when a user selects other.
Colors.odkbuild (818 Bytes)
> Thanks again.
>> Hello ,
>> or_other
>> Best,
> "ODK Developers" group.
> email to opendatakit-developers+unsubscribe@googlegroups.com.
Dear Yaw,
Many thanks for updating me, I will check it.
Kiflu T.
question.
Minilik,
box
Thanks again.
Hello ,
or_other
