Help on question skips
Dear all,
I am stuck on some skip functions and i need help. I have attached some questions and those highlighted in yellow are the ones that I need help on.
Thanks you all for your help.
SKIP-HELP.docx (41.7 KB)
Hi @Rod
You need to apply some relevant conditions to your form in order to work.
Check out how to use the function : https://opendatakit.org/help/form-design/binding/
For more assistance provide more clarifications and attach your xls form.
Dear Dickson,
Thank you so much for the quick reply. I need more assistance and please find attached the xls form and the word doc on which you will find the questions.
Thank you in advance for your help.SKIP-HELP.docx (41.7 KB)
questions_skips.xlsx (66.4 KB)
You said "Number If 0! Q29" in first line what does this mean?
After reading question doc file i want to discuss with you one point with you that if any user will enter 0 in Q21 then , Q23 should be shows to user, not go on q29. If "Number If 0! Q29" means skip to Q29. If i understand your code incorrect then make me correct so, I can help you.
Narendra
"Number If 0! Q29" if Number is 0 then skip to question 29
Thank you so much for helping
Hi @Rod,
I find you word doc a bit tricky to understand . Have tried to implement what i understood
See is the form ,
skip.xls (26 KB)
skip.xml (7.5 KB)
Regards
Dickson
Thank you Dickson.... This worked
