Hi, I am very new to using ODK and have been creating a form to collect data on Google Drive using ODK build. I've noticed from reading a few threads that ODK build doesn't support adding images to either questions or answers and have been trying to add these in the XLSform instead as suggested. I have added a media::Image column on the survey sheet as I would like and image to appear that helps users with how to take particular measurements we are collecting. I have then tried to convert the XLSform into an XML document using the following link: https://getodk.org/xlsform/ so I can upload it to google drive to download on ODK collect. When I try to convert the document using that website I receive the following error message: "Error: Media type: Image not supported".
I was wondering if I could get some advice on how to convert XLSforms to XML documents that have media in, and also further clarification of where I need to store these images when using Google Drive?
I have been using ODK Collect on Android v.1.27.3, ODK Build and the website https://getodk.org/xlsform/ to convert XLSforms to XML documents.
I have tried watching multiple youtube videos but none describe this problem of receiving an error message. I have also read the advice given here on how to attach media to your XLSforms: https://docs.getodk.org/collect-forms/#loading-form-media
Create a number decimal question using ODK Build, download as an XLSform, add a media:Image column to the survey sheet and add the desired image name and extension to the number question, and finally try to convert to an XML document using the following link: https://getodk.org/xlsform/
