How to use multiple fields as triggers on a calculation (a OR b etc)
(putting this in showcase as it's more of an example than a support issue, move as needed)
Surfacing some new (to me) info about multiple triggers so that searches / kapa can find the updated solution and help others
So ${trigger1} or ${trigger2} doesn't work, as previously discussed :up_arrow:, but trying this now gave a new and intriguing error:
On the 'survey' sheet, the 'trigger' value is invalid. Reference variable lists must have a comma between each variable.
Then trying ${trigger1} , ${trigger2} , the form validates and functions in Enketo, Web Forms & Collect. As does ${trigger1} , ${trigger2} , ${trigger3}
My assumption was that pyxform has been updated to parse multiple OR triggers into multiple setvalue actions, which was always possible previously but required some handcrafted XML. I also assume that an AND trigger is still not possible at this time.
The documentation would benefit from an update to indicate this useful new xlsxform ability. I had a look back through pyxform / docs issues and saw this was introduced in Sept 2025! But there was a silent failure in earlier pyxform versions that stopped any mention or doc updates, looks like it's all resolved via #780 now?
Example form to try multiple triggers:
multiple-trigger.xlsx (84.1 KB)
Thank you! We kept adding to the top of the todo list so this hasn't made its way back up. But you're absolutely right that it's now supported! :tada:
