If Statement Problem
Dear Friends,
I need help with a conditional statement. Under which column and how do I
write an if statement in xls form.
For example, if i have a multiple answer question 'A' and after that an integer field "B', then if we select any from the multiple answers 'A' then we cannot skip 'B' (as these fields are not mandatory). How can I put condition to integer field 'B'? At which column I can write if statement? in odk xlsform??
Rumana
Hi @Rumana_Dilshad
We're glad you're here. When you get a chance, please introduce yourself on this forum thread.
If I understand your case you don't need any if statement. You should use relevant and required columns like:
relevantAndconstraintTest.xlsx (8.1 KB)
Thank you again. I will introduce myself later
