I have successfully installed central-odk on the EC2 instance, and everything is running properly. Now, how do I access the central frontend??
I have tried editing the inbound rule for port 8989, but I still can't access the login page.
I am also attaching the screenshot of the status of my instance.
Why do you need to talk directly to the frontend? I would only open port 80 (HTTP) and 443 (HTTPS) in your security groups, then connect to the API over HTTPS.
Thanks for your reply, but I didn't understand. I have installed odk-central on EC2 and digital ocean successfully. Now, I am able to access this
from digital ocean public IP address after deployment. However, I am not able to access it from EC2.
Now I am able to access it. I got help from this post - ODK Central Installation Unreachable
Thanks for all your help.
