I want to put numeric box and choice button in the same question.
Example
Q. What is your Age?
Answer:
a numeric box and a choose button which contain "don't know" should be display
Hi @sanish_shrestha
such a widget doesn't exist. Maybe a good solution is to use two separate widgets but on the same page (a group with field-list
appearance).
Regards,
Grzegorz
Something similar was discussed HERE, where a work around option is provided. Hope this helps.
Hello friends,
If I write age number in field box then "don't know" should not be select or if I select "don't know" then we should not write any number in field box
So, how can we wrote that logic?
Sanish
One option is to create a constraint
on the age question such as .<125 or .=777 or .=999
and provide instructions for your enumerator (e.g. with a hint
) to "enter 777
if the respondent does not know or 999
if the respondent prefers not to answer".
