ODK Central v2025.2: Search and filter Entities, Entity permissions, and more usable groups and repeats in Web Forms
What’s new
ODK Central v2025.2 is here it's all about Entities (and a little bit about Web Forms)!
:magnifying_glass_tilted_left: Search and filter Entities
Entities have been updated with additional search and filter features so you can more quickly find the data you are looking for!
:locked_with_key: Control Entity access with new permissions
Data Collectors and App Users now have the option to access either all Entities in a project or only the Entities they have created.
:ledger: Server upgrade is logged
When Central is upgraded, there is now an event in the System audit log labeled “Server Upgrade”. You can filter upgrade events to see when new features were added.
Web Forms
:star_struck: More usable groups and repeats
Groups and repeats no longer have indented vertical lines. Instead, they are in containers with reduced indenting to make forms more usable on devices.
:magnifying_glass_tilted_left: Select one with search fixed
We've improved filtering so that the choices shown are based on choice labels. The filtering is case-insensitive and matches any subset of the label text.
:glowing_star: See highlight for last ranked option
In previous releases, it was hard to know which item you just moved. Now, the last option is highlighted temporarily to provide feedback.
:thought_balloon: Use disabled selects & multi-line text
Form designers can now use disabled selects when a question is read-only. We’ve also added support for multiline appearance in the text question type intended for longer responses.
How to get these improvements?
If you are using Central on ODK Cloud, we'll be rolling out these updates in the coming weeks. If you are self-hosting Central, follow the upgrade instructions!
What’s next
Our next release will include creating Entities from repeats and changing Entity ownership. We’ll also be working on refreshing the login experience to allow for branding opportunities.
Web Forms will add more support for geospatial questions and improve selects with images. We'll also be providing some resources to help you build more usable web forms!
See more of what we have planned at https://getodk.org/roadmap.
ODK Central v2025.2.1 is now available. It includes the following changes:
  • Bug fix: apply filters to download of Submissions CSV in UI
  • Allow App Users, Data Collectors, and Public Access Links to send Submission Attachments from ODK Web Forms
  • Fix issue with Public Access Links that are used offline in Enketo
  • Update ODK Web Forms to 0.13.1
ODK Central v2025.2.2 is now available. It includes the following changes:
  • Bug fix: show space in Enketo when space is passed through d[...] query parameter instead of + sign (issue)
ODK Central v2025.2.3 is now available. It includes the following changes:
  • Fixed: Public access links with last-saved instance (issue)
  • Fixed: space character in the URL is shown as ‘+’ in Enketo for the prefilled value after redirection (issue)
  • ODK Web Forms upgraded to v0.14.0, which improved numeric fields & error feedback: Numeric inputs are now limited to a maximum of 9 digits, integer fields no longer allow decimal values, and error highlighting has been enhanced, making required questions easier to identify and fix before submitting. (more details)
