Hi everyone,
I noticed a problem since the release of the version 1.16.0 with geopoint and placement-map.
First, the button "add a mark", which place automatically a point on the GPS position, is not active. Then, when I want to place manually a point on the map, I have to push on "delete point" before being enable to place the point on the map.
All is right with version 1.15.1 but troubles appear with version 1.16.0 and 1.16.1.
I have tried those different version on Samsung Galaxy Tab A (Android version 6.0.1 and 7.0) and Samsung Galaxy tab 2 (Android version 4.2.2). The trouble is the same.
The parameters of my GPS allows Google services to enance its precision, I am connected to the net and I am in a place without any problem to find a signal.
Does anyone notice the same kind of trouble ?
Thanks for help !
Helene
