This is intended to be the final beta for v1.25 in preparation for a release on or around December 11th.
ODK Collect betas are an opportunity to get community feedback on upcoming releases. If you have an ongoing data collection campaign, we recommend quickly verifying your form on a test device. The release will be delayed until all reported issues are fixed.
Joining the beta program
Leaving the beta program
You can leave the beta program from the bottom of the Play Store at any time. Once you leave, you will get the next production update when it is released. If you need to go back to the previous production release, uninstall and reinstall the app. Your settings will be reset but your forms will remain (though backups are always recommended).
What to check in this release
- Newly-downloaded forms with a geopoint question outside of a repeat should show a map of filled forms from Fill Blank Form. Read more at Visualize on the fly in the mobile phone the data collected with ODK on a map - #19 by LN.
- Select option spacing has been reduced from the first beta. Please verify that options are still easily tappable. Read more at ODK Collect v1.25 Beta: preview of increased spacing for selects - #19 by mathieubossaert. @Dominik @dicksonsamwel @mathieubossaert @Odil @aurdipas
- Google Sheets submissions now should only send raw values with a ' in front of them for questions of type text, select multiple and barcode. Read more at Apostrophe in front of each answer in formula bar causing problems with formulas in other sheets @Mcrollin, @famador, @sneike
- The
likertappearance onselect_onequestions displays a Likert scale. Read more in the documentation. - Audits can now be configured to request a user identifier on form open and reasons for changes on form close. Try it with form "Collect v1.25: audit identify-user and track-changes-reasons demo" on default server (https://opendatakit.appspot.com).
Extra testing
If you have some time, please also verify the other changes in the release notes:
- https://github.com/opendatakit/collect/releases/tag/v1.25.0-beta.1
- https://github.com/opendatakit/collect/releases/tag/v1.25.0-beta.2
Thanks to all testers for your help!
