Highlights
Counter question: makes it easier to count things. Read the documentation or try it out with this form.
Map scale: scale in the upper left of maps to help with distance estimates
Thai Buddhist calendar question: try it with this form.
New submission sending order: oldest are now sent first
Audio question indicator: required icon is now shown
Downloading Entity Lists and looking up values have been fully re-implemented to support offline Entities. For now, forms do not create or update Entities offline by default. The next Central version, expected in mid-December, will update all Entity-related forms to opt into offline Entities. If you would like to try this functionality before the next Central release, you can use Central v2024.2.0, add an offline column to the entities sheet, and put yes under it.
Patches
- v2024.3.1 - Nov 20, 2024
- Fix crash when Entity List name has special characters
- v2024.3.2 - Nov 22, 2024
- Bring back configuration by QR code image import which was accidentally removed
- v2024.3.3 - Dec 10, 2024
- Improve handling of duplicate columns with different case
- Throw an exception when there is an attempt to access a file outside of the Collect directory
- v2024.3.4 - Jan 21, 2025
Download release
- https://play.google.com/store/apps/details?id=org.odk.collect.android (recommended)
- ODK-Collect-v2024.3.4.apk
If you want to read more, see our detailed release notes. As always, let us know what you think.
Want to know whatβs next? Check out our roadmap.
