ODK Collect v2026.1: Prevent self-intersections, guidance hints shown by default, and more!
:triangular_ruler: Prevent self-intersections while mapping
Invalid shape example
When mapping a perimeter, navigating obstacles can create self-intersections which lead to expensive rework. To solve this problem, Collect now supports an intersects function that prevents self-intersections in geotrace and geoshape questions.
For even higher-quality mapping, add the incremental=true parameter to enable real-time feedback and detailed guidance that data collectors can use to fix self-intersections on-site. Try it out with this sample form!
:sparkles: Smaller improvements
We’ve added polish to make data collection feel smoother and more intuitive.
  • Guidance when you need it: Hints are now visible by default. Previously, guidance hints were not shown by default. They are now shown collapsed unless explicitly configured to be turned off or always shown.
  • Consistent exit experience: We’ve updated the exit dialogs for markups and signatures. They now match the rest of the app, so whether you’re saving a form or a sketch, the experience feels consistent.
  • Cleaner bottom sheet on map: We’ve removed unneeded metadata, like __version,__trunkVersion, and __branchId, from the Select from map bottom sheet, and increased the font size to make it easier to skim.
:hammer_and_wrench: Coming soon
  • Entities from repeats: We’re in the home stretch! We are fine-tuning the last few details of this feature. Stay tuned...
Download the release
If you want to read more, see our detailed release notes. Let us know if you have any feedback!
Want to know what’s next? Check out our roadmap.
We have now released ODK Collect v2026.1.1 which fixes an accidental change in the geotrace and geoshape format reported by @Edmonds here. Submissions made from Collect v2026.1.0 included a space after the semicolon separating multiple points which may require special handling in analysis and processing. Collect v2026.1.1 removes that space to match previous versions. Many thanks for the quick report, @Edmonds.
