Release highlights
- v2.0.0 - Apr 17, 2020
- Upgrade to pyxform v1.1.0, Validate v1.14.0, JavaRosa v2.17.0
- Upgrade to PyInstaller v3.6 and wxPython v4.0.7
- Detailed release notes: https://github.com/opendatakit/xlsform-offline/releases/tag/v2.0.0
Breaking changes
- Resulting form definitions now have a slightly different structure. Learn more in this post.
- Collect will now always show a first instance of the repeat before prompting the user to add more.
- If you are updating a form that has already been deployed, you may need to add a
nameon the settings sheet with a value that matches the form filename. For example, if your filename ismy_survey.xlsx, putmy_surveybelowname.
Download release
Report issues
Big thanks to @estbergm and @PieterBenjamin of University of Washington's Impact++ for designing a reproducible build process for Windows and MacOS. ![]()
