Odkmeta: column header type not found. invalid type() suboption. invalid survey() option
Hello,
I am having an issue described in a previous post, getting the following error:
The command I am using is just:
odkmeta using odkmetado, csv("$data\baseline_180909.csv") survey("$survey\survey.csv") choices("$survey\choices.csv") replace
I was not sure if my .csv files had any non-ASCII characters, so I tried stripping them (not sure if that was successful). I am attaching my survey.csv (77.4 KB) and choices.csv (44.1 KB) files for your reference. Is it still the encoding or could the issue be something else? Appreciate your help - I am really not sure what my next steps are.
Hi @yuliab! When you get a chance, please introduce yourself here. Thanks for uploading survey.csv and choices.csv, as that definitely aids debugging.
When I run odkmeta for survey.csv and choices.csv, I actually see a slightly different error message:
column header label not found
invalid label() suboption
r(111);
This error message is issued because survey.csv does not contain a column named label. However, you can specify a different column using suboption label():
odkmeta using odkmetado, ///
	csv("$data/baseline_180909.csv") ///
	survey("$survey/survey.csv", label(label:english)) ///
	choices("$survey/choices.csv", label(label:english)) ///
	replace
See the help file for more details about this suboption.
Also, am I right that you added the first column of survey.csv and that it just contains the row number? If that's the case, you should be able to (and will likely need to) remove that column before specifying survey.csv to odkmeta.
When I take these steps, I'm able to run odkmeta without error. Given that type is the first column once the row-number column is removed, I think that means that there is no issue with Unicode characters.
Hope that helps!
I also have the following messages after running odkmeta:
Could you suggest the possible solutions?
Ko Zaw
University of Public Health
Yangon
Hi @kokozaw! The most common reason for this error message is an encoding issue. See the discussion here and here and let us know if that helps.
Dear Matthew White
Thank you for your response. I will try to solve the problem as you advised.
Regards
Ko Ko Zaw
Dear Team,
So, 8 months later, I am using ODK collect and testing to export my data from ONA server and use odkmeta to generate the Stata dofile; but I kept getting that exact error message;
column header name not found
invalid name() suboption
invalid choices() option
I read the discussions here and tried some of the recommendations but so far I have not fixed it. I am using stata 15 in case that has something to do with it. Could someone please help me fix this issue?
Thanks all for the help!
Hiwot
Welcome @hiwot_mekonen! When you get a chance, please introduce yourself here. Doing so helps build community!
odkmeta creates a do-file that imports submission data that matches the ODK Briefcase export CSV format. I'm not sure whether data exports that you prepare from within Ona match this format, though I seem to recall that they don't. However, you should be able to connect ODK Briefcase to Ona, then export your data using ODK Briefcase; you can then use the odkmeta do-file to import the resulting data.
However, first you need to use odkmeta to create the do-file, and it seems that you are running into an issue in this step. I've used odkmeta with Stata 15, so I don't think that's the cause. (Stata also has excellent version control, such that odkmeta should continue working in new versions of Stata.)
What is the full odkmeta command that you are running? Are you able to share your XLSForm?
Hello,
I am Jado, working on a HAPIN Trial project.
I am facing with the same issue.
I wanted to share with you an issue I am facing while trying to work with odkmeta.
In fact, while running the odkmeta dofile, I am getting the following error message:
Here are csv files that I am using:
I would appreciate if you can help.
Jado
Hi @jntivuguruzwa, and welcome to the ODK forum! When you have a chance, I'd encourage you to introduce yourself here. Doing so helps build community!
It looks like your survey CSV file contains non-ASCII characters, specifically ’, “, ”, and •. As long as those characters only appear in the label column, you should be able to remove them or replace them with corresponding ASCII characters (for example, replacing ’ with ' and “ and ” with ").
For more discussion about odkmeta, Unicode, and non-ASCII characters, see the discussion here and here.
Hope this helps!
