I tried logging in to a build account I haven't used for a while to work on a form. The build website wouldn't accept my password so I tried getting a new password. This apparently reset the password but I don't receive any reset emails. I tried again and i now have 3 accounts and can't access the forms.
To get around this I am looking for a way to import forms from aggregate into build but can't seem to make that work either.
Aggregate (works), build.opendatakit.org (issue), collect (works). Emails are not turning up and it is just gmail on my end.
main issue is reset password on build doesn't send email after resetting pass. Email working fine apart from this. So, reset password and don't receive a reset email. I am using gmail
resetting pass, importing form from aggregate
I am now a bit confused on which account was my original and has the forms.
Looking through the search results it looks like I am not alone with this issue.
- can't log in
- reset pass to gain access
- server resets but doesn't send email with reset instructions
- create another account to use build
- can't find a way to import form into new account to use build ->aggregate as before.
thanks, Shaun.
