Désolé l'enregistrement du formulaire a echoué java.lang.boolean cannot be cast to java.lang.integer 2. What app or server are you using and on what device and operating system? Include version numbers.
ODK collect 3. What you have you tried to fix the problem?
i try anything 4. What steps can we take to reproduce the problem?
After a quick look, I noticed the repeat count on row 907 has the expression ${nm0}>0. The repeat count expects an integer value but the expression will return a Boolean ( true or false ). Replacing the expression with ${nm0} might resolve the issue.
You form seem to have other errors/mistakes you need to fix too. You have used "select1" instead of "select_one"question type in over 60 occurrences (934, 925, 920, 866, 860, 431, 362, 360 and others). You also seem to have designed the cascade question wrongly. Use the ODK recommended design https://docs.getodk.org/form-logic/#filtering-options-in-select-questions.
I made the xls file work (see attached) but for the cascade question since I don't see to know/understand what you aim to do. Enquete_PDM_SO4_DEC2021_V2A.xlsx (319.8 KB)
