Dear users,
i am using vysor offline, it was well working previously, today sadanly do not connect my android, i reinstalled it and ADB was downloaded, but still i could not connect my mobile, is there any one experienced this issue, or is there any other offline alternative for vysor?
Is the issue related to any of the tools under ODK?
no, but some members of this community guided me to use vysor for connecting android to computer, at the time, it was will working but unfortunately, now i faced with problem.
Have you tried the alternatives described in Showing ODK Collect form with projector? I believe all should work offline.
Go through with below link this will very helpful for you.
http://docs.opendatakit.org/projecting-collect/
Narendra
Thank you every one, and special thanks @LN for your guidance for ever, solved.
