Would like to view form submissions in a read-only view.
A project at my organization is using a log based data validation system that handles multiple data types well. The log is essentially a CSV that flags issues in the data and requests human review (e.g. for submission ABC, a temperature reading is out of range). While the system can handle simple survey questions, it can be difficult for users to get the proper context when there are more complex patterns. For example, there is a multiple select question with an other option. If other is selected, the enumerator may enter the response as free text. Sometimes, the free text actually corresponds to an option and the should be selected in the multiple select question.
Being able to access a read-only view of the submission would make contextualizing the response much easier.
Not applicable
Looked through documentation for enketo and odk central to see if this could be implemented.
https://docs.getodk.org/central-submissions/#submission-editing >> nothing here to indicate a view only option is possible
https://github.com/kobotoolbox/kpi/issues/2607 >> seems like with kobotoolbox this could be possible. I would prefer a solution in odk central.
Integration of Enketo into ODK Central >>> seems like this was on the docket at some point but I don't see it in my version of odk-central
Not applicable
