I have developed a form and tested it using ODK 1.27.3 I then updated all tablets to 1.28.2 prior to field deployment all to realize the repeats and calculations inside them respond differently. I have nested repeats inside which I calculate several labels and recap values to help enumerators keep on their finger tips. In version 1.28.2 the label calculations work the first repeat and fails for the subsequent ones except the most inner repeat.
Example for quick debugging will be variable ${bmr_lbl} on Row 60 it would display fine for HIV_MAM_MALE but would only show --FEMALE upon next repeat. This doesn't happen with ODK 1.27.3 though
We use ONA alike managed server services
I downgraded ODK to last working version (1.27.3) but would still want to understand what is causing the issue in between
One can upload the form and download it to both the ODK 1.27.3 and 1.28.2 to see how they repeats responds differently
I am attaching the form and the control media files for testing
@lognaturel you've helped me in the past with similar complex forms and would really appreciate if you take a look and let me know what i might be doing wrong or if this is bug in which case I would revert to earlier version until fixed
Many thanks in advance
Jules R
--- XLSFrom and Media files are here attached ---
Digital_IFP_Filing_202010.xlsx (21.4 KB) getClosing.csv (16.1 KB) getFacility.csv (892 Bytes) getScreen.csv (465 Bytes) IFP_Closing.csv (9.1 KB)
