According to Installing Central on DigitalOcean β ODK Docs, I've tried to change my SMTP settings to:
"email": {
"serviceAccount": "no-reply@MY-DOMAIN.com",
"transport": "smtp",
"transportOpts": {
"host": "smtp.office365.com",
"port": 587,
"auth": {
"user": "no-reply@MY-DOMAIN.com",
"password": "MY-PASSWORD"
The SMTP account requires auth, STARTTLS, but not SSL.
The the logs this error is shown:
service | Error: Missing credentials for "LOGIN"
service | at SMTPConnection._formatError (/usr/odk/node_modules/nodemailer/lib/smtp-connection/index.js:591:19)
service | at SMTPConnection.login (/usr/odk/node_modules/nodemailer/lib/smtp-connection/index.js:340:38)
service | at /usr/odk/node_modules/nodemailer/lib/smtp-transport/index.js:270:32
service | at SMTPConnection.<anonymous> (/usr/odk/node_modules/nodemailer/lib/smtp-connection/index.js:188:17)
service | at Object.onceWrapper (events.js:291:20)
service | at SMTPConnection.emit (events.js:203:13)
service | at SMTPConnection.EventEmitter.emit (domain.js:494:23)
service | at SMTPConnection._actionEHLO (/usr/odk/node_modules/nodemailer/lib/smtp-connection/index.js:1113:14)
service | at SMTPConnection._processResponse (/usr/odk/node_modules/nodemailer/lib/smtp-connection/index.js:747:20)
service | at SMTPConnection._onData (/usr/odk/node_modules/nodemailer/lib/smtp-connection/index.js:543:14) {
service | code: 'EAUTH',
service | command: 'API'
versions:
647569c54f6bbf26ea356eca0d14f7e5d1a89c6b
cddb691e40e84aabff87b9d427e22a50282d6f99 client (v1.1.2)
a33bc6fb3c34fe38894b0e9d0bb404f81da325e6 server (v1.1.1)
Set secure
to true
, false
and remove it completely as suggested here
Maybe it's hard unless you have an office365 account...
