Trying to migrate my ODK deployment and its data from AWS to Digital Ocean
Hello,
My ODK deployment works fine on AWS. However, I would like to move the current deployment as well as its current data/state to a new virtual machine on Digital Ocean (while maintaining the domain name). Any ideas on how to achieve this in the fasted and safest way possible?
The following assumes you're comfortable on the command line and with basic networking. Also, I haven't tried this recently so I'd strongly recommend you try this out on a test install before doing it on a production install.
Pre-reqs
  • Verify your full machine backup and restore works.
  • Verify you can whitelist traffic to Central only from your IP. An upstream firewall is great for this.
  • Verify you have the same OS on the source (src) and destination (dest). If you don't, the folders noted below may not match. Adjust adjust accordingly.
  • Verify you can set the TTL of the DNS record on the domain to something low (~300 secs) to reduce downtime.
  • Verify you have an effective way to communicate a maintenance window with users.
Migration
  1. Take a full machine backup of src.
  2. Over ssh, rsync the key folders (/var/lib/docker, /root/central) from src to dest. This might take some time.
  3. Start the maintenance window.
  4. Block all incoming HTTP/S traffic to src.
  5. Shutdown Central on src with docker-compose stop;
  6. Rsync the key folders from src to dest again to pick up the latest changes to data. This will be faster than the first rsync.
  7. Shutdown src and take another full machine backup.
  8. Only allow incoming HTTP/S traffic only from your IP to dest.
  9. Update the DNS record to point to the dest. This should happen quickly if your DNS TTL is low.
  10. Bring the dest server back up (docker-compose build; docker-compose up -d).
  11. Verify you can login via the Central UI to dest, see records, preview forms, etc.
  12. Allow all incoming HTTP/S traffic to dest.
  13. Stop the maintenance window.
Notes
  • If you value speed over safety, you can skip the backups. I don't recommend it.
  • Running the first rsync outside the maintenance window should be safe, but if you want to be extra safe, you can run it after blocking all incoming traffic.
Thanks for your update.
Please confirm by running sync command, it'll migrate the users and databases etc?
Yes, it will move everything about the install including users and data.
Thanks for your quick response.
One question, how can we renew the Letsencrypt SSL for odk central server?
LetsEncrypt certs renew automatically.
I much appreciate your support. You are the guru. :+1:
Hello @yanokwa.
Users aren't receiving emails like forgot password. Shall we need to add mail server host, port, and authentication details in .env ? Or this will work without adding
See https://docs.getodk.org/central-troubleshooting/#users-aren-t-receiving-emails.
Dear @yanokwa,
I wanted to know that how many days before expire letsencrypt ssl automatically renew? As our letsencrypt SSL will be expire on Wednesday, September 6, 2023.
On the server I see the logs and its saying below logs:
2023/08/04 11:44:25 [info] Starting certificate renewal process
2023/08/04 11:44:25 [info] Requesting an ECDSA certificate for 'odk.xxx.xxx.org' (http-01 through webroot)
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Certificate not yet due for renewal
Certificate not yet due for renewal; no action taken.
Can you please help me with this?
LetsEncrypt certs auto-renew as necessary (typically every 90 days). You can check the various renewals at https://crt.sh/?q=odk.xxx.xxx.org to see if everything is working as expected. From what you've showed in the logs, it is working. Maybe set a calendar even for Sept 1 and check the cert then.
We seeing the attached output.
At docker-compose build I'm getting
 - LegacyKeyValueFormat: "ENV key=value" should be used instead of legacy "ENV key value" format (line 14)
postgres14.dockerfile:1
   1 | >>> FROM postgres:14.10
   2 |
   3 |     COPY files/postgres14/start-postgres.sh /usr/local/bin/
ERROR: failed to solve: failed to register layer: rename /var/lib/docker/image/overlay2/layerdb/tmp/write-set-702993805 /var/lib/docker/image/overlay2/layerdb/sha256/fb1bd2fc52827db4ce719cc1aafd4a035d68bc71183b3bc39014f23e9e5fa256: file exists
ERROR: Service 'postgres14' failed to build : Build failed
any hint about how to solve this? I'm following your post/instructions to the letter.
thanks in advance
@yanokwa I have been able to move on after issuing a
docker builder prune -a
anyway now I face a new issue. The resulting Central instance on the new server works. The domain/host name is the same as the original, forms work, what is not working in enketo. The container is up, but forms do not open. The new server is behind a reverse proxy, so I adapted .env and docker-compose.yaml as decribed here
Strange thing, a clean install with the same configs (on the reverse proxy too) results in enketo working without problems.
What could be the issue? Thanks in advance.
Just to note that the above steps worked ok again for me once to migrate my Central instance to a new server. I’m still affected by Central: containers not starting after boot, do start manually with "docker compose up" even after upgrading to Central latest version after the migration. Not really sure how to fix that (other than restarting the containers after boot), I would appreciate any pointer.
Hi @manghig ,
Not sure if it’s just that but have you tried docker compose up -d (or - - detach)?
“Running docker compose up --detach starts the containers in the background and leaves them running.”
of course. Issuing that manually (or with cron) after boot the containers start ok, they do not start as expected automatically after rebooting the system.
  1. Is docker engine running as a service?
sudo systemctl enable docker
  1. Is the container restart policy set correctly?
docker inspect --format='{{.HostConfig.RestartPolicy.Name}}' <container_name_or_id>
Should be "always" or "unless-stopped"
You can check that also on the docker-compose.yml file at Central’s folder:
less docker-compose.yml
  1. If a container depends on a network share or another service, it might fail to start if the dependency is not available when Docker attempts to start it. Review container logs for connection errors.
docker container logs <container_name_or_id>
  1. Monitor system logs for docker service errors:
journalctl -u docker.service
May be helpful to see docker post install steps
