Using ODK collect, Can I display all questions in single vertical scroll view rather than horizontal scrolling?
I have integrated odk collect in android app to have the dynamic form facility, I did it and now I am able to successfully run the project.
But one of my requirement is to display all the questions in a single page in vertical scrollview, right now in odk colect it is horizontally scrollable..
If yes then what are the changes I need to do in the code?
I tried by making the questionHolder LinearLayout's orientation as vertical but it did not worked.
Please suggest me the way to go..
hi @arajuasati, yes it is possible. you have to put all the question you want to appear on one page in a group. for example;
type = begin group
appearance = field-list
with this all the question within the group will be display on one page with a scroll bar depending the number of questions in the group.
if you are not clear with this you can share a sample file so that we can help you with that.
thank you.
fabla2020@gmail.com
@anon38864895 Where do I need to place this type and appearance in android code ?
OR did you mean I need to put these in xml of that form ?
yes, or in your excel form, you can share a sample of your form here so that we can help you with that.
I am not able to share the complete xml here..
@anon38864895 Any suggestion?
I have added type = begin group and appearance = field-list in my xml and its working as I wanted.. Thanks
Where exactly we have to add a type and appearance in XLS form
Hi @Hariharan_S
We're glad you're here. When you get a chance, please introduce yourself on this forum thread.
Here you can find everything about the structure we use in xls forms https://xlsform.org/en/
