I've been doing some more looking into creating an HTML/printable
version of a ODK Form. Since ODK is based on XForms, I started looking
more into XForms and HTML. A few things I found that I'd be interested
in getting feedback on:
Orbeon: seems like a pretty slick tool that lets you build XForm
based forms. It supports display as HTML and PDF and a fillable HTML
form.
Have other used this or looked into it?
What would it take to make this work with ODK?
XForms vs HTML5 Forms. I ran into discussion about the future of
web forms and XForms vs HTML5 Forms. My main take aways.
Future in web browsers: XForms will likely never be directly
incorporated into standard web browsers while HTML5 forms may be
Power and Complexity vs Simplicity: XForms spec is complex and
forms are harder to create, but you can create very powerful complex
forms. HTML5 Forms are more simple, but does not allow for the same
level of power-complexity in the actual forms.
ODK does not support all of the XForms spec, but I assume it was
choose because it was the open standard of choice at the time.
Thoughts?
I'm wondering where people see things going and where it is best to
focus resources/effort?
It seems an HTML client for ODK would be big feature, both in
terms of effort and benefit.
Do others agree?
How big is a job is this?
Where would you start?
with something like Orbeon?
Javascript libraries that interpret XForms markup
Some transform layer for making an XForm and HTML5 form w/
extra JS?
this is an excellent line of thinking. We have been considering
creating a new capability for xls2xform (see xls2xform.opendatakit.org
and childcount.org) that would have it generate HTML5-compatible
Javascript from the same specification that we know use to generate
Xforms. Most of the structure is there to this. What needs to be
figured out is the template for each question type and how to make it
easy to include arbitrary code (unlike Xforms) so that people can do
more flexible forms with arbitrary behavior. Our hope it to
eventually have a version of ODK that would simply execute the
Javascript in a WebView. We have been playing with some ideas for
making each question an object that has methods for computing default
values, checking constraints, which question to advance to next
(data-driven gotos), etc. If you would like to pursue this further, I
would welcome the opportunity to make some specific plans for how we
could get this done. I think the first part, making forms that are
viewable in a browser should be relatively straightforward.
Gaetano
> 1. Orbeon: seems like a pretty slick tool that lets you build XForm
> form.
> - Have other used this or looked into it?
> - What would it take to make this work with ODK?
> 2. XForms vs HTML5 Forms. I ran into discussion about the future of
> - Future in web browsers: XForms will likely never be directly
> - Power and Complexity vs Simplicity: XForms spec is complex and
> - ODK does not support all of the XForms spec, but I assume it was
> - Thoughts?
> 3. I'm wondering where people see things going and where it is best to
> - It seems an HTML client for ODK would be big feature, both in
> - Do others agree?
> - How big is a job is this?
> - Where would you start?
> - with something like Orbeon?
> - Javascript libraries that interpret XForms markup
> - Some transform layer for making an XForm and HTML5 form w/
> extra JS?
> Feedback and thoughts are appreciated.
> Thanks,
> Matt
If you are just trying to get forms entered on the web you might want
to look at touchforms and typeforms[1] which are web-based ways to
play forms one-question-per-screen in a browser using jython and
django. There are two UIs, one optimized for touchscreens and one
optimized for keyboard entry.
The good thing about them is that they use the underlying form engine
inside JavaRosa and ODK to render the form, which means all the
underlying functionality of the clients is available in the browser.
The bad thing about them is that they use the underlying form engine
inside JavaRosa and ODK to render the form, which means every question
is an ajax request, and you need a web server to call out to the
underlying jar.
We are working on multi-question-per-screen support in the next month,
but it will still not be a pure HTML5/JavaScript app.
I love the idea of something 100% client side, but the duplication and
recreation of the forms engine underneath the hood has always been a
sticking point for us.
On Wed, Sep 21, 2011 at 5:54 PM, Gaetano Borriello wrote:
> Matt:
> Gaetano
>> form.
>> - Thoughts?
>> - Do others agree?
>> extra JS?
>> Thanks,
>> Matt
One of my immediate goals is to create a printable version of the
form, allowing the survey to be used with ODK Collect and a paper
version without having to manage two copies (ODK Build and Word/
Excel). Long term however, I see a fillable HTML5 version that
supports offline entry as being very useful, so if I solutions that
head in that direction are appealing.
So what I'm looking for is a bit different than touchforms and
typeforms. I can see how using the underlying form engine is both an
advantage and disadvantage.
What I want actually seems similar to xls2xforms, but in reverse.
Gaetano, how complete is the conversion structure you're putting
together? Does it support conditional logic, validation, etc.
I'm still wondering about Orbeon. It appeared to support conditional
logic, validation, calculated fields, web based submission with some
control over layout and PDF form generation. Any reason why there
isn't ODK/Orbeon integration?
Matt
> underlying jar.
> Cory
> [1]https://github.com/dimagi/touchforms
> > Matt:
> > Gaetano
> >> form.
> >> - Thoughts?
> >> - Do others agree?
> >> extra JS?
> >> Thanks,
> >> Matt
> >> Options:http://groups.google.com/group/opendatakit?hl=en
We have built a system here at the Carter Center that does both HTML
and ODK/XForms. I haven't tried printing them but I'd say they'd look
pretty nice.
We are also planning offline fillable functionality in the medium
term. Also planning to open source it. Perhaps we should collaborate.
On 22 September 2011 09:48, Matt Langeman wrote:
> Hi Cory and Gaetano,
> Thanks for the responses.
> Matt
>> underlying jar.
>> Cory
>> > Matt:
>> > Gaetano
>> >> form.
>> >> - Thoughts?
>> >> - Do others agree?
>> >> extra JS?
>> >> Thanks,
>> >> Matt
I'm definitely interested in hearing more. Any change I could see a
demo? What platform is it built on?
Matt
> pretty nice.
> > Matt
> >> underlying jar.
> >> Cory
> >> > Matt:
> >> > Gaetano
> >> >> form.
> >> >> - Thoughts?
> >> >> - Do others agree?
> >> >> extra JS?
> >> >> Thanks,
> >> >> Matt
To see what a form looks like, go Responses -> Create New Response ->
Choose Starbucks v2 -> Click Go
Let me know if you have any questions.
On 22 September 2011 10:34, Matt Langeman wrote:
> Hey Thomas,
> Matt
>> pretty nice.
>> > Matt
>> >> underlying jar.
>> >> Cory
>> >> > Matt:
>> >> > Gaetano
>> >> >> form.
>> >> >> - Thoughts?
>> >> >> - Do others agree?
>> >> >> extra JS?
>> >> >> Thanks,
>> >> >> Matt
pretty nice.
question
underlying jar.
month,
and
it
do
default
further, I
we
looking
interested
XForm
HTML
form.
of
and
complex
same
was
Thoughts?
best to
Do others agree?
w/
extra JS?
If we keep uppermost in our minds the unkind and unjust acts of others, we
shall find it impossible to love them as Christ has loved us; but if our
thoughts dwell upon the wondrous love and pity of Christ for us, the same
spirit will flow out to others.
Thanks - it works now. Very neat implementation. How do you download forms
to ODK? Is your server set to sync with ODK wirelessly or is there an option
to download the XML form?
Just point your ODK instance to https://secure2.cceom.org. Make sure the
form you want to download is marked 'published.' The green up arrow
publishes a form. Use the same credentials. If you just want to see the XML,
try https://secure2.cceom.org/forms/4.xml, where '4' is the ID of the form
you want to see. You can discover ID's by showing or editing a form and
looking at the URL in the address bar. (This is a bit obtuse as users aren't
usually expected to want to see XML.)
> On Fri, Sep 23, 2011 at 7:46 AM, Thomas Smyth wrote:
>> Tino, it seems to be working for me. I even clicked on the link in your
>> email. Make sure you use https not http.
>> On 23 September 2011 00:04, Tino Kreutzer wrote:
>>> Hi Thomas,
>>> I'm having trouble connecting to your site. If I visit
>>> https://secure2.cceom.org I get "Coming soon: Another fine website
>>> hosted by WebFaction ." If I go to
>>> https://cceom.org/ and enter login: ddemo, password:tryMEout - I get
>>> 'Login is not valid'
>>> Did you already disable the login or is there something I didn't
>>> understand?
>>> Would love to try the site.
>>> Thanks,
>>> Tino
>>> On Thu, Sep 22, 2011 at 12:47 PM, Thomas Smyth wrote:
>>>> Sure. Try https://secure2.cceom.org, login: ddemo, password: tryMEout
>>>> > Hey Thomas,
>>>> > Matt
>>>> >> pretty nice.
>>>> an
>>>> conditional
>>>> some
>>>> >> > Matt
>>>> want
>>>> engine
>>>> browser.
>>>> engine
>>>> question
>>>> >> >> underlying jar.
>>>> month,
>>>> and
>>>> a
>>>> >> >> Cory
>>>> >> >> > Matt:
>>>> HTML5-compatible
>>>> generate
>>>> be
>>>> make it
>>>> can do
>>>> for
>>>> default
>>>> further, I
>>>> how we
>>>> are
>>>> >> >> > Gaetano
>>>> >> >> > On Wed, Sep 21, 2011 at 1:53 PM, Matt Langeman < mklange...@gmail.com> wrote:
>>>> HTML/printable
>>>> looking
>>>> interested
>>>> XForm
>>>> HTML
>>>> >> >> >> form.
>>>> future of
>>>> directly
>>>> be
>>>> and
>>>> complex
>>>> same
>>>> it was
>>>> >> >> >> - Thoughts?
>>>> best to
>>>> in
>>>> >> >> >> - Do others agree?
>>>> form w/
>>>> >> >> >> extra JS?
>>>> >> >> >> Thanks,
>>>> >> >> >> Matt
BTW hi Daniel! Do you remember me from Uganda, 2008, Makerere? Where
are you working now!?
On 22 September 2011 14:56, Daniel Kayiwa wrote:
> Hi Thomas,
> I get a "Password is not valid" error message when i use: login: ddemo,
> password: tryMEout
>> > Hey Thomas,
>> > Matt
>> >> pretty nice.
>> >> > Matt
>> >> >> want
>> >> >> engine
>> >> >> question
>> >> >> underlying jar.
>> >> >> month,
>> >> >> and
>> >> >> Cory
>> >> >> > Matt:
>> >> >> > generate
>> >> >> > it
>> >> >> > do
>> >> >> > default
>> >> >> > further, I
>> >> >> > we
>> >> >> > are
>> >> >> > Gaetano
>> >> >> >> looking
>> >> >> >> interested
>> >> >> >> XForm
>> >> >> >> HTML
>> >> >> >> form.
>> >> >> >> of
>> >> >> >> and
>> >> >> >> complex
>> >> >> >> same
>> >> >> >> was
>> >> >> >> - Thoughts?
>> >> >> >> best to
>> >> >> >> in
>> >> >> >> - Do others agree?
>> >> >> >> w/
>> >> >> >> extra JS?
>> >> >> >> Thanks,
>> >> >> >> Matt
On 09/22/2011 09:56 PM, Daniel Kayiwa wrote:
> Hi Thomas,
> On Thu, Sep 22, 2011 at 7:47 PM, Thomas Smyth <thomas.smyth@gatech.edu > wrote:
> On 22 September 2011 10:34, Matt Langeman <mklangeman@gmail.com > wrote:
> > Hey Thomas,
> > Matt
> HTML
> they'd look
> >> pretty nice.
> collaborate.
> >> On 22 September 2011 09:48, Matt Langeman <mklange...@gmail.com > wrote:
> solutions that
> both an
> conditional
> with some
> >> > Matt
> might want
> ways to
> and one
> form engine
> browser.
> form engine
> every question
> >> >> underlying jar.
> next month,
> duplication and
> always been a
> >> >> Cory
> >> >> On Wed, Sep 21, 2011 at 5:54 PM, Gaetano Borriello <gaet...@cs.washington.edu > wrote:
> >> >> > Matt:
> considering
> >> >> > and childcount.org ) that would
> generate
> needs to be
> to make it
> people can do
> ideas for
> computing default
> next
> this further, I
> for how we
> that are
> >> >> > Gaetano
> >> >> > On Wed, Sep 21, 2011 at 1:53 PM, Matt Langeman <mklange...@gmail.com > wrote:
> HTML/printable
> started looking
> be interested
> build XForm
> fillable HTML
> >> >> >> form.
> future of
> directly
> may be
> complex and
> powerful complex
> for the same
> assume it was
> time.
> >> >> >> - Thoughts?
> it is best to
> feature, both in
> >> >> >> - Do others agree?
> HTML5 form w/
> >> >> >> extra JS?
> >> >> >> Thanks,
> >> >> >> Matt
> others, we shall find it impossible to love them as Christ has loved
> us; but if our thoughts dwell upon the wondrous love and pity of
> Christ for us, the same spirit will flow out to others.
pretty nice.
want
engine
question
underlying jar.
month,
and
generate
it
do
default
further, I
we
are
looking
interested
XForm
HTML
form.
of
and
complex
same
was
Thoughts?
best to
in
Do others agree?
w/
extra JS?
Thanks for the demo info. I was able to try it. I noticed there are
places for conditional logic, but I wasn't able to figure out how to
set up that functionality. Is it in place or are those just
placeholders?
Matt
On Sep 22, 3:35 pm, Daniel Kayiwa wrote:
> Sam,
> Try it again now. It works.
> On Thu, Sep 22, 2011 at 9:58 PM, Samuel Mbugua wrote:
> > Thomas,
> > Am getting "Password is not valid" too.
> > Hi Thomas,
> > password: tryMEout
> >> Sure. Tryhttps://secure2.cceom.org, login: ddemo, password: tryMEout
> >> > Hey Thomas,
> >> > Matt
> >> >> pretty nice.
> >> >> > Matt
> >> want
> >> engine
> >> question
> >> >> >> underlying jar.
> >> month,
> >> and
> >> >> >> Cory
> >> >> >> > Matt:
> >> generate
> >> it
> >> do
> >> default
> >> further, I
> >> we
> >> are
> >> >> >> > Gaetano
> >> looking
> >> interested
> >> XForm
> >> HTML
> >> >> >> >> form.
> >> of
> >> and
> >> complex
> >> same
> >> was
> >> >> >> >> - Thoughts?
> >> best to
> >> in
> >> >> >> >> - Do others agree?
> >> w/
> >> >> >> >> extra JS?
> >> >> >> >> Thanks,
> >> >> >> >> Matt
Very nice pages. How is the html generated? What specification do
you start from?
Gaetano
On Thu, Sep 22, 2011 at 2:47 PM, Matt Langeman wrote:
> Hi Thomas,
> placeholders?
> Thanks,
> Matt
>> Sam,
>> > Thomas,
>> > Hi Thomas,
>> > password: tryMEout
>> >> > Hey Thomas,
>> >> > Matt
>> >> >> pretty nice.
>> >> >> > Matt
>> >> want
>> >> engine
>> >> question
>> >> >> >> underlying jar.
>> >> month,
>> >> and
>> >> >> >> Cory
>> >> >> >> > Matt:
>> >> generate
>> >> it
>> >> do
>> >> default
>> >> further, I
>> >> we
>> >> are
>> >> >> >> > Gaetano
>> >> looking
>> >> interested
>> >> XForm
>> >> HTML
>> >> >> >> >> form.
>> >> of
>> >> and
>> >> complex
>> >> same
>> >> was
>> >> >> >> >> - Thoughts?
>> >> best to
>> >> in
>> >> >> >> >> - Do others agree?
>> >> w/
>> >> >> >> >> extra JS?
>> >> >> >> >> Thanks,
>> >> >> >> >> Matt
Yes it works. Currently there can only be one condition per question.
Plans to add multiple condition ability.
To get it to work you have to have a prior question to which
conditions can be applied. Then you choose from the dropdowns and away
you go. The interface for conditions is a bit rough, I know. It was
something of a rush job. Plans are to clean it up when we have some
time.
Any other questions? Do you think it would suit your needs?
On 22 September 2011 17:47, Matt Langeman wrote:
> Hi Thomas,
> placeholders?
> Thanks,
> Matt
>> Sam,
>> > Thomas,
>> > Hi Thomas,
>> > password: tryMEout
>> >> > Hey Thomas,
>> >> > Matt
>> >> >> pretty nice.
>> >> >> > Matt
>> >> want
>> >> engine
>> >> question
>> >> >> >> underlying jar.
>> >> month,
>> >> and
>> >> >> >> Cory
>> >> >> >> > Matt:
>> >> generate
>> >> it
>> >> do
>> >> default
>> >> further, I
>> >> we
>> >> are
>> >> >> >> > Gaetano
>> >> looking
>> >> interested
>> >> XForm
>> >> HTML
>> >> >> >> >> form.
>> >> of
>> >> and
>> >> complex
>> >> same
>> >> was
>> >> >> >> >> - Thoughts?
>> >> best to
>> >> in
>> >> >> >> >> - Do others agree?
>> >> w/
>> >> >> >> >> extra JS?
>> >> >> >> >> Thanks,
>> >> >> >> >> Matt
The forms and questions and options and etc. are all specified via the
same app (see Forms, Questions, Options, etc., on the menu). Those
form definitions are then viewable via the web or in ODK.
Authentication is also integrated for web and ODK.
Offline web forms are high on our priority list as TCC has lots of
long term observers filling out longer forms on laptops with no
connectivity.
I need to write all this up at some point, but we have our first major
deployment on Saturday so I've been defining forms like a madman. The
longest one has 58 questions
Feel free to send more questions.
On 22 September 2011 19:05, Gaetano Borriello wrote:
> Thomas:
> you start from?
> Thanks,
> Gaetano
>> Hi Thomas,
>> placeholders?
>> Thanks,
>> Matt
>>> Sam,
>>> > Thomas,
>>> > Hi Thomas,
>>> > password: tryMEout
>>> >> > Hey Thomas,
>>> >> > Matt
>>> >> >> pretty nice.
>>> >> >> > Matt
>>> >> want
>>> >> engine
>>> >> question
>>> >> >> >> underlying jar.
>>> >> month,
>>> >> and
>>> >> >> >> Cory
>>> >> >> >> > Matt:
>>> >> generate
>>> >> it
>>> >> do
>>> >> default
>>> >> further, I
>>> >> we
>>> >> are
>>> >> >> >> > Gaetano
>>> >> looking
>>> >> interested
>>> >> XForm
>>> >> HTML
>>> >> >> >> >> form.
>>> >> of
>>> >> and
>>> >> complex
>>> >> same
>>> >> was
>>> >> >> >> >> - Thoughts?
>>> >> best to
>>> >> in
>>> >> >> >> >> - Do others agree?
>>> >> w/
>>> >> >> >> >> extra JS?
>>> >> >> >> >> Thanks,
>>> >> >> >> >> Matt
This looks great, I'd love to take a look at the underlying
implementation. Is it open source or are there plans to open source
it?
thanks,
Cory
> connectivity.
> longest one has 58 questions :)
>> Thomas:
>> you start from?
>> Thanks,
>> Gaetano
>>> Hi Thomas,
>>> placeholders?
>>> Thanks,
>>> Matt
>>>> Sam,
>>>> > Thomas,
>>>> > Hi Thomas,
>>>> > password: tryMEout
>>>> >> > Hey Thomas,
>>>> >> > Matt
>>>> >> >> pretty nice.
>>>> >> >> > Matt
>>>> >> want
>>>> >> engine
>>>> >> question
>>>> >> >> >> underlying jar.
>>>> >> month,
>>>> >> and
>>>> >> >> >> Cory
>>>> >> >> >> > Matt:
>>>> >> generate
>>>> >> it
>>>> >> do
>>>> >> default
>>>> >> further, I
>>>> >> we
>>>> >> are
>>>> >> >> >> > Gaetano
>>>> >> looking
>>>> >> interested
>>>> >> XForm
>>>> >> HTML
>>>> >> >> >> >> form.
>>>> >> of
>>>> >> and
>>>> >> complex
>>>> >> same
>>>> >> was
>>>> >> >> >> >> - Thoughts?
>>>> >> best to
>>>> >> in
>>>> >> >> >> >> - Do others agree?
>>>> >> w/
>>>> >> >> >> >> extra JS?
>>>> >> >> >> >> Thanks,
>>>> >> >> >> >> Matt
Yaw and others: I had to take down the demo site b/c our server plan has
limited memory and we're doing an active deployment tomorrow. I will try to
rectify this early next week. Thanks again for your interest.
On 23 September 2011 09:21, Cory Zue wrote:
Hi Thomas,
it?
connectivity.
placeholders?
HTML
look
pretty nice.
medium
collaborate.
the
paper
Word/
that
both an
reverse.
putting
conditional
with some
there
might
want
ways to
and
one
form
engine
the
browser.
engine
question
the
underlying jar.
next
month,
duplication
and
been a
considering
HTML5-compatible
generate
needs to be
to make
it
people can
do
to
the
ideas for
computing
default
next
further, I
for how
we
that
are
HTML/printable
started
looking
be
interested
build
XForm
fillable
HTML
form.
future
of
directly
may be
complex
and
powerful
complex
the
same
assume it
was
time.
Thoughts?
it is
best to
both
in
Do others agree?
HTML5 form
w/
extra JS?
others, we
our
same
others, we
our
same
Sorry, I go sidetracked last week. A few suggestions regarding the
implementation and UI. I like the way you can have "saved" questions
and option sets. A similar idea has been suggested by some of our
survey creators. If they have 5 choice questions, with the same 5
options, it is tedious in ODK Build. However, I do like how easy it is
in ODK Build to add a new question, re-order, etc. From what I
remember with the UI in your demo it the flow was that you needed to
first create option sets, then questions, then add it to the survey.
Also, if you wanted to have a similar question, but with slightly
different wording or options, you would need a whole new question.
What I think would be great, at least for the way we have been doing
surveys, is being able to quickly copy questions/option sets. I guess
there is a chance that you actually want to make sure it is the exact
same question/options, if you are doing comparison across surveys. So
maybe you need something like copy-new and copy-use options. Am I
making any sense?
Matt
> > Hi Thomas,
> > it?
> > thanks,
> > Cory
> > > connectivity.
> > >> Thomas:
> > >> you start from?
> > >> Thanks,
> > >> Gaetano
> > >>> Hi Thomas,
> > >>> placeholders?
> > >>> Thanks,
> > >>> Matt
> > >>>> Sam,
> > >>>> > Thomas,
> > >>>> > Hi Thomas,
> > ddemo,
> > >>>> > password: tryMEout
> > >>>> > On Thu, Sep 22, 2011 at 7:47 PM, Thomas Smyth < thomas.sm...@gatech.edu>wrote:
> > tryMEout
> > >>>> >> > Hey Thomas,
> > a
> > >>>> >> > Matt
> > HTML
> > look
> > >>>> >> >> pretty nice.
> > medium
> > collaborate.
> > the
> > paper
> > Word/
> > that
> > both an
> > reverse.
> > putting
> > conditional
> > with some
> > there
> > >>>> >> >> > Matt
> > might
> > >>>> >> want
> > ways to
> > and
> > one
> > form
> > >>>> >> engine
> > the
> > browser.
> > engine
> > >>>> >> question
> > the
> > >>>> >> >> >> underlying jar.
> > next
> > >>>> >> month,
> > duplication
> > >>>> >> and
> > been a
> > >>>> >> >> >> Cory
> > >>>> >> >> >> > Matt:
> > considering
> > HTML5-compatible
> > >>>> >> generate
> > needs to be
> > to make
> > >>>> >> it
> > people can
> > >>>> >> do
> > to
> > the
> > ideas for
> > computing
> > >>>> >> default
> > next
> > >>>> >> further, I
> > for how
> > >>>> >> we
> > that
> > >>>> >> are
> > >>>> >> >> >> > Gaetano
> > HTML/printable
> > started
> > >>>> >> looking
> > be
> > >>>> >> interested
> > build
> > >>>> >> XForm
> > fillable
> > >>>> >> HTML
> > >>>> >> >> >> >> form.
> > future
> > >>>> >> of
> > directly
> > may be
> > complex
> > >>>> >> and
> > powerful
> > >>>> >> complex
> > the
> > >>>> >> same
> > assume it
> > >>>> >> was
> > time.
> > >>>> >> >> >> >> - Thoughts?
> read more »
